Help: Piece of Fricking Plastic Broken
Location: Somewhere in between Lynn, MA (home) and Lakeland, FL (school)
K, so the little egg-shaped piece of plastic that controls the secondary meetering rod holder to move with the secondaries on my buddy's carb has broken in half. I've been to 4 partshops and 1 carb rebuilding place, the general concensus is go looking in a junkyard.... At this time, there are no quadrajets in junkyards in the area.
Meanwhile, my buddy's carb is disasembled in his garage, and his car is going nowhere.
Anyone know where i can get the part???????
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Here's another option, if you don't have someone to bail you out:
http://www.carbs.net/quadrajet.asp
hehe, thanks. 99Hawk120 actually sent me the exact same page and i ordered one through them.
Thanks for the help!
1 Post
Car: 3
Engine: inboard
Transmission: underfloor
I had the exact same problem a couple of months back, I had a post about it. Once I found the problem I kicked myself for spending hours changing fuel filters, adjusting AV tension and swapping secondary rods. I have a couple of marine parts carbs lying about and I got one out of them.
Eric
Eric
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
