Choke Light
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Does it buzz? If so check the choke heater fuse, otherwise check the choke relay or the alternator.
[This message has been edited by Apeiron (edited November 08, 2001).]
Car: 4
Engine: 6
Transmission: 5
It's the "Alternator" light too. You probably need one of those.
ICON Motorsports
ICON Motorsports
Car: 4
Engine: 6
Transmission: 5
You need an alternator. Doesn't matter whether the choke relay is buzzing or not. Get yours tested. Don't fiddle around with a bunch of esoteric "maybe it's the wobbulator overbiasing the feeblevetzer" crap.
"The simplest explanation that fits all the facts is usually the right one"
—Occam, ancient Greek philosopher from the days of external voltage regulators
ICON Motorsports
ICON Motorsports
Car: 82 camaro SC
I agree, check the easy stuff first--the alternator.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
82camaro
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
Just take the dash face off and put black electrical tape over the little choke light window.
Problem solved and talk about simple!
If the car runs fine and is charging, why would he need an alternator?
