L69 L hanger
Car: 84 TA
Engine: 305 L69
L69 L hanger
Thats what my car has along with DR rods. The car runs great but am I missing something? In my searches this dosen't seem to be a common hanger. Should I try another hanger?
84 Trans Am HO L69 WS6
5 Speed manual
Vortech Cherrybomb no cat
Removed A/C A.I.R. Hdflap
H/made cld air induction
K&N
Otherwise STD
Currently painting
5 Speed manual
K&N
Otherwise STD
Currently painting
Car: Camaro sc
Engine: 350 cid.
I'm running a "E"hanger in place of the "L"hanger i used to have,big difference when you set them side-by-side.My problem is finding a set of those DR rods that everyone is so fond of.I swear,every carb i check for metering rods has the L hanger,ch rod combo in it.Does this "carbs unlimited"place have a web sight?Any other place you can buy metering rods?
86'Camaro Berlinetta SC,former 2.8,now 350 cid,4 bolt main.94'TPI 350 heads(pocket ported),420-442 lift summit cam,cloyes double roller timing set,Modified q-jet carb(e hanger,ch rods)700-r trans(rebuilt)3:42 gears,t-tops,b&m megashifter,grant wheel,fresh headliner,Macewen white face gauges,American racing wheels..Dedicated to those who enjoy scrounging through junkyards more than throwing money for new stuff...
I bought my DR rods from GM, part # 17053659. Check out http://www.carbs.net/index.htm for for rods and hangers. MtCamaro, the CH rods are stock. I went with AH rods with G hanger first, then DR rods with G hanger. Both are improvements, big improvements, over stock.
JamesC
[This message has been edited by JamesC (edited October 25, 2001).]
JamesC
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
B hangar is in the car now. That's what was recommended by a Quadrajet guru. You can get it from Edelbrock(P.N. 1960) a whopping $2.95 each.
Carburated 5-speed
Vortec heads,1.6 roller rockers, .480 Crane cam,T-5,355 4-bolt, 3.73 posi,SSM Kit
Carburated 5-speed
Car: 1984 Camaro Z28
Engine: Blueprint 383
I just ordered B & G hangers from Summitracing.com for 2.69 each (or 2.96) shipping cost more than the two hangers.
Craig
I ordered the DR rods from my local chevy dealer for $12.74. Not sure yet if this is for the set or one. They have to special order but it only takes a couple of days.
84 Z28 305HO, 5spd, 222,000 miles, Edelbrock intake, Hedman headers, low restriction exh(w/cat), K&N air filter, 14.630 at 93.17mph
Del-A-lum front control arm bushings, Moog ball-joints, Energy suspension front sway bar end links, Moog rear sway bar end links, Eibach pro-kit springs, tokico shocks/struts, AU secondary rods
www.indycamaro.com
[This message has been edited by Craig84Z (edited October 30, 2001).]
Craig
www.indycamaro.com
Car: 84 TA
Engine: 305 L69
Thanks guys, its been awhile since I posted this but it's looking like I should try both a G and a B hanger. With the new cam and headers, maybe the B will be the way to go?
5 Speed manual
JB Headers
Comp Cams XE262H-10
H/made tri cld air induction
K&N
Otherwise STD
Currently painting
5 Speed manual
JB Headers
Comp Cams XE262H-10
K&N
Otherwise STD
Currently painting
Re: hard starting
Thanks sofakingdom, I guess i better get ready to replace the starter, what a great time to change it in the middle of winter,brrrrr.
I was hoping it was just frozen.
1992 Trans Am
05-10-2023 07:19 PM
Chuck84TA
07-15-2016 09:05 PM
Night rider327
10-13-2015 01:47 AM
