Won motor from e-bay auction.Question about carb.
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
I won an auction for an unfired,375hp 4-bolt 350 from e-bay a couple days ago.Complete from oil pan to air cleaner.It comes with a Carter 750 carb. Since all my other 3rd gens have been fuel injected,I have little experience with carbs.So my question is, is this a decent carburetor? I don't hear about it as much as Holley,Edelbrock,etc.
'91 RS 5.0 TBI
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
ASCD SS hood, High-rise Z-28 spoiler,shaved handles/antenna,
Hooker super comp headers,dual 3" exhaust(yeah,too much for my set-up,but it was free!),two 1-chamber Flomasters,Eibach Sportline springs,KYB struts/shocks,rebuilt steering linkage,Iroc sway bars,IROC steering box,wonderbar,140 Iroc gauge cluster,Auto meter gauges,dual guage A-piller pods,open air filter,AFPR,smog delete
TBI mods,180* thermostat,
383 stroker in the works
President-Austin 3rd Gen F-body c.c.
Austin 3rd Gen F-body c.c. message board at
www.hpsmotorsports.net
See my car and others at www.ride4life.net
'91 RS 5.0 TBI
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What kind of Carter is it? If it's a new AFB, it's the same as an Edelbrock. I wouldn't be surprised if they're even made side-by-side in the same factory.
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Give it a try and see if you like the Carter. IF not then go with the best a Holley. ![](https://www.thirdgen.org/messgboard/biggrin.gif)
383 86 Camaro Z28 ---1/4 mile et>13.65@103mph,,
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,3500 stall converter,shift kit,4.10 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.ALSO SECOND GEN Z28---mods:454 BBC,.546 max lift(doug herbert cam ) 750 Holley vac sec. ,Edelbrock Performer manifold,Holley electric fuel pump,Hooker headers,Flowmaster mufflers,beefed up 700r4 tranny, 3.90 gears, powertrax unit, B&M console shifter.
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Carter is or was a manufacturer of q-jets... are all carter carbs q-jets? I would say that it is as good as a rochester q-jet and there are few quality complaints... You probably wont notice the difference between it, a demon, holley or edelbrock.
Engine: 383 Carb
Transmission: 4L60
Carter did make a few Quadrajets on contract from Rochester, but they primarily made their own carburetors.
theshackle
09-17-2020 08:26 AM
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
