need carberatur suggestion.....
My friend just got a 1979 pontiac firebird formula with 301 and 2 barrel carn which is stock. He wants to get a 4 barrel and he will need a new intake manifold. Which carberatur do you guys recommend and how many cfm would be good. Also which intake manifold would be a good choice. Thanks alot.
- Red '91 Z-28 350
- 700-R4 Trans
- T-tops
- no major power
gaining mods, K&N
Filter, Flowmaster
exhaust -series 80-,
exhaust cut-outs - Best E.T.= 14.7@93.8mph,
- HardlinePerformance
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
625 Road Demon.Dont know much about the 301 but i would recommend a Performer intake from Edelbrock if they make one for the 301.I wouldnt recommend going much bigger than 650 cfm on a 301 as these are not a high horse motor.
1982 Z28:355,4 Speed,Lots of bolt ons
Car: 1989 C4
Axle/Gears: 307
Im going against my personal standards here but. It is true that these 301's are thought of as below lg4 305's as 350's are above 305's, thats alot. So heres where my standards come into the picture I would suggest that your friend get a 1406 edelbrock. Thier cheap, easy to work on and there would be no problems running this carb in stock form on the 301. Holleys/Deamons are picky and need to be tunned for smaller engines.
AS far as intakes go stay away from the "stock replacement" ones because they really dont flow that much better than stock, I cant justify the 110$ for these manifolds any more when they do little over stock. I would suggest going for a "Performer RPM" or "Wieand Stealth" Do it right the 1st time.
Good luck!
SSC
Good luck!
SSC
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I use to have a 79 GRand Prix that had a 301. I agree with the small carb idea. It took me about 1/4 mile to hit 5k rpm in 1st gear. They don't like to rev very high. And when you make them, they blow up, like mine did.
I would even go as far as suggest dropping in a 305 at least. They are much cheaper, and run better too. Even one of the junk yard variety. Hey, I would even give him mine if he wants the TPI that is on top of it.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust,Dynomax Bullet Mufflers, T&R Motorsports custom air intake
Joshua Johnston
1991 Z-28
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I am able to say that Edelbrock seems to be a good company, and aside from the 1% that hate them from experience... I can't say anything bad... the idle screws are in a much more reasonable place than holleys (just my own experience). 600 CFM ought to be plenty, keep in mind that by dropping to 550 or 500 you will save some gas, and you will probably still gain a little Hp over that little 2 barrel.
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
A 600 cfm Holley vac.seconaries for$ 201.95 sounds about right for this setup.
383 86 Camaro Z28 ---1/4 mile et>13.65@103mph,,
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,3500 stall converter,shift kit,4.10 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.ALSO SECOND GEN Z28---mods:454 BBC,.546 max lift(doug herbert cam ) 750 Holley vac sec. ,Edelbrock Performer manifold,Holley electric fuel pump,Hooker headers,Flowmaster mufflers,beefed up 700r4 tranny, 3.90 gears, powertrax unit, B&M console shifter.
