aircleaner ?
aircleaner ?
Will edelbrocks pro flow 1000 fit on to our Q-Jets ? It has an advertised 5 1/4 inch base I think and I didn't know if it would fit. If it does and to any one who has used one did you like it?
Thanx
speed is a good thing,
more speed is a better thing
86' SLOW LG4 bone stock
except for a K&N
Future Mods: T56
350-383
miniram
Thanx
except for a K&N
Future Mods: T56
350-383
miniram
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Yes, it will fit. Q-jets, Holleys, and Edelbrocks all have the 5-1/4" air cleaner mount base.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Car: 4
Engine: 6
Transmission: 5
That's a terrible piece. I knew a number of people when it came out who ruined engines by way of it getting sucked in; and others who had it catch fire. On your car, with a hood, it's going to put the air pickup right at the top, in the hottest part of the engine room. It's not a go-fast piece at all, it's for people who want something that looks cool and don't care about performance (street rods & show cars).
ICON Motorsports
ICON Motorsports
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
It fits and it shouldn't cause a problem unless you install it wrong... I have noticed no difference between it and a 14x3 open element performance wise... if it were truly problematic, then it would be pulled from the shelves... also, the foam part is good for many thousands of miles... I am perfectly happy with it...
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
If this is true, the microscopic bits of foam will just burn up and probably won't even see the cylinders...
