holley sniffer test
Car: 91 RS
Engine: 350 H.O.
holley sniffer test
Im currently running a holley 600 carb with the vacuum secondars on my 91 camaro 350 with a california emisions legal cam. I was wondering if I prevented the back barells from getting fuel, and lean the front barrels, could I possibly pass the emmisions test, I have a brand new cat, and full exhaust with no leakes. Or if anybody else knows anything else I can do to help me pass, thanks I need more time so I can put a tpi kit on my car
1991 teal camaro RS rebuilt 96 350 marine motor, comp cam, accel ignition,8mm accel plugs and wires, flowtech headers, stock exhaust, and rear end. (2.73)
You should be able to pass with ease. You might not even have to do anything to the carb...I'd give it 50/50 it'll pass as is.
If you really wanna be on the safe side..just open up a couple small vacuum leaks..like one or both of the small ports under the front of your carb. Then lower the idle speed to compensate and call it good.
Stop a block before the emissions place and do it...then stop a block after and fix it.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
JSP Motorsports
ICON Motorsports
Car: 2002 SOM z28
That's usually what I do along with reducing the timeing a little... watch for the glowing headers too! Visual is what kills me ![](https://www.thirdgen.org/messgboard/frown.gif)
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Hotrodboba400
12-10-2019 07:07 PM
