Hey Greearhr??
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Hey Greearhr??
...how many jet sizes did you go down?I am running a 750 DP on my 355 and am at 70 primary..77 secondary and am curious to see where abouts everyone is jetted at for their engine combo.I have a 10:1 355,afr 195's,xtreme energy 274 cam,stealth intake and 750 DP speed demon with a 4 speed and 3.73's.Thanks for the help so far everyone!!I'm getting there.
John
John
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
sounds cool,i'll check tomorrow!Thanks for all your help,i really appreciate it.My car is starting to run pretty damn good finally.
Car: chevy s10,1986camaro
Engine: 406sbc
Transmission: 350turbo
What size squiters are u guys useing? And do your cars idle rich with the demon carbs? Mine sure does. I completely closed the sec throttle blades and idle mix screws and that seems to have helped a little. U guys have any more ideas? I'm sitting at 69prim and 75sec jets with #25 squiters.
406SBC
-DART SPORTSMAN 2 HEADS
-RPM INTAKE
-750 SPEED DEMON MECH SEC. CARB
-HEDMAN HEADERS
-COMP CAM EX .507/.510
-1.6 roller rockers
-th350 tranny
-posi rear disc
406SBC
-RPM INTAKE
-HEDMAN HEADERS
-1.6 roller rockers
-th350 tranny
-posi rear disc
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
i have 28 primary and 25 secondary squirters in my demon.i am at 70 primary 77 secondary jets,but still rich including at idle.I have my mixture screws about 1.5 turns out on all 4 circuits.Just keep playing with the idle mixture with a vacuum gauge,i managed to clean my idle up quite a bit by doing this repeatedly,and the car doesnt hunt for an idle anymore,it finally has a set RPM.I dont think we'll ever have a lean idle due to the size of the carb and cam combo.But i could be wrong,any suggestions from others?!?!
John
John
