rejetting carb..
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
rejetting carb..
I am in the process of jetting my Demon to suit my motor and the question i have is .. after i change the jets do i need to reset the idle mixture on the carb? I think i have read that the jets have no effect on the idle mixture but am not 100% sure. The car still idles and runs fine but i want to be sure,and i have been to lazy to hook up a vacuum gauge to see where i am at. Any help is appreciated..Thankx in advance.
John
John
Right, jets wont affect the idle as long as the butterflies aren't open enough to expose the transfer slot. On my 750 Speed Demon I had to go down several sizes.
Bear Tracks
Bear Tracks
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
hey greearhr ...how many jet sizes did you go down?I am running a 750 DP on my 355 and am at 70 primary..77 secondary and am curious to see where abouts everyone is jetted at for their engine combo.I have a 10:1 355,afr 195's,xtreme energy 274 cam,stealth intake and 750 DP speed demon with a 4 speed and 3.73's.Thanks for the help so far everyone!!I'm getting there.
John
John
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
My current setup has 67primaries 75 secondaries. I usually tune my carb by reading the plugs.
383 86 Camaro Z28
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,3500 stall converter,shift kit,3.42 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.ALSO SECOND GEN Z28---mods:454 BBC,.546 max lift(doug herbert cam ) 750 Holley vac sec. ,Edelbrock Performer manifold,Holley electric fuel pump,Hooker headers,Flowmaster mufflers,beefed up 700r4 tranny, 3.90 gears, powertrax unit, B&M console shifter.
383 86 Camaro Z28
