Edelbrock 600 CFM ??'s
I have a 355 with a Edelborck 600. It was the manual choke model, but the electric choke has been added. After some changes to the springs, the carb runs great. BUT, when you really stick your foot in it the car blows fuel smoke out the pipes. You can see the cloud hanging behind you. Its not oil smoke either (new motor and you can smell it). I cannot see a 600 dumping to much fuel for a 350, so there must be something wrong somewhere. I have a 750 DP on it and it never smoked. Any ideas??
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Car: 82 camaro SC
Keep tuning, your running too rich. The CFM is how much AIR the carb will flow. It has nothing to do with how much fuel it will supply.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
Sounds like you need jet and/or rod changes. Make sure your needle/seat assemblies are not stuck open and that the float levels are ok and FP not too high, If those are fine, you'll need the Edelbrock Tuning kit for that carb. Enough rods and jets and springs and directions in there to get you right.
1 Post
Car: 99 Formula
Axle/Gears: 342
I'm having the same problem, the smell of gas and the cloud of smoke, plus black powder on the tailpipes, I would think these carbs would come adjusted properly without running rich.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
Exhaust Cut-Out and different gears, either 3:73 or 3:42
"There is nothing more addicting than speed"
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
160* Stat
2:73 GEARS
B&M Megashifter
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
<font face="Verdana, Arial" size="2">Originally posted by Mark A Shields:
I would think these carbs would come adjusted properly without running rich.</font>
Car: 1983 Z28
Engine: 6.6L 406
<font face="Verdana, Arial" size="2">Originally posted by 82camaro:
</font>
</font>
Did you just bolt the carb on? Have you tried dialing in the A/F mixture? Is the timing right?
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package , dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
Car: 1989 C4
Axle/Gears: 307
The carb you describe is built for performance, number 1404/1405 I think. The jets and rods compared to a 1406 larger. You are not getting enough air in higher rpms to burn all the fuel so I would drop down the secondary jets untile the problem goes away.
SSC
SSC
As I suggested, by the Edelbrock Tuning kit for your carb P/N. Go to there website and there are some sample AF problem instructions there. You will also need to do some ignition curve fine tuning, I am sure...
There is no way a single carb could be setup perfectly for every situation/engine. If a carb could do that by itself OOB, it would outsell all other carbs combined.
Guest
Posts: n/a
Generally they are rich right out of the box. Dont ask me why.
I'd suggest a carter strip kit or the edelcrock kit, and tune it. More than likely you will have to drop the rear jet sizes by 4 and the fronts by 2, depending on what they stuck in it. The rods with the largest drop from the upper to lower diameter generally give the best driveability, and put the pump shot one step above the lowest setting. Thats a good starting point, then go from there.
Thanks guys. I figured it was rich, but I was stunned by how much. Yes, this is the "performance" 600. I just called and ordered my new springs and struts, so I added a kit to it.
Besides the problem, the carb ran fine out of the box. I guess they set them a tad rich to be on the safe side. I would rather be rich than lean!
Thanks again.
Thanks again.
efiguy
09-27-2015 01:30 PM
Dragonsys
09-25-2015 03:51 PM
Night rider327
09-25-2015 04:47 AM
