Those of you with drop base air cleaners...
Car: '82 Z28
Quick question for you. For the 14" model with a drop of 7/8", did you have to buy the offset one to clear the HEI distributor? I plan on getting the K&N model 60-1430 but want to make sure it'll fit properly before ordering. Thanks.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The one I have is 1-1/4" drop. I didn't have trouble with clearance for anything. The only issue I had was the fresh air PCV inlet that goes to the stock air cleaner housing - 3/4" nipple breather cap took care of that.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Car: '82 Z28
Thanks for the quick help Another item gets checked off the list of things to do hehehe. Next on the list, a possible 327 engine swap to take place of the 305
