Adding tweeters..............
I was thinking of buying tweeters. Can I splice them into my 6 x 9's and mount them close by? Any opinions on using tweeters?
92 Camaro RS
305 TBI
T-Tops
DynoMax Cat-Back Exhaust
Gutted Cat
Hypertech Street Runner Chip
K&N open element
Gabriel Struts
Lakewood Drag Shocks
Custom Interior
Window Tint
Prestige Alarm
Foglights
JVC El-Kameleon Head Unit(w/ remote)
Pyramid 6 x 9's
(bass blockers)
Jensen 5 1/4's
2- 10" Kenwood Tornado Subs
Pyramid 600 Watt Amp
Best ET: 15.976 @ 86.28 mph
reaction time: 0.479
60 ft: 2.269
92 Camaro RS
305 TBI
T-Tops
Gutted Cat
K&N open element
Gabriel Struts
Custom Interior
Window Tint
Prestige Alarm
Foglights
Pyramid 6 x 9's
(bass blockers)
Jensen 5 1/4's
60 ft: 2.269
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Yeah you could do that. Most tweeters come with a passive crossover, so you'll be fine.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Just something I noticed. First where are you placing the tweeters? If you're putting them in the front you want to splice into your front speakers. If you are putting them in the back, what's the need? The 6x9's simply fill in the area behind you, some people like it some don't. Either way I woulden't want a tweeter firing into my ear from the rear.
I'm not critisizing your decision, just curious.
-Matt
[img=http://members.fbody.com/flashz28/SIG.jpg[/img]
-Matt
currently, i have my tweeters on the piller between the windshield and doors, but im ripping them out soon ... they should be lower. One of my car buddies mounted his into his heater vents in his civic .... it was sweet.
1991 Firebird (GT40)
-LO3 305 TBI
-5 speed
-Open Element Air Filter
-Edelbrock Tower Strut Brace
-Kenwood Excelon Headunit w/ 10 Disc Changer
-Alpine MRP-F256 Amp
-Polk EX 4x6's, DX 6x9's, and EX Tweeters
-Kicker ZR240 amp (bridged)
-Dual JL W0 12" Subs
My page with pics and stuff, and car stereo help.
http://members.aol.com/deadtrend1/index.html
-LO3 305 TBI
-5 speed
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
What Amp are you using to power the 6x9's? If you're using the decks internal amp and you wire 4ohm tweeters in parallel with the 6x9's you will have a two ohm resistance and your decks amp will shut down because it can't handle a two ohm load. If you're using a 4 channel 600 watt amp to power the 6x9's and subs most aftermarket amps can handle the 2 ohm load and you won't have any problems. Just talking from experience, I wired two pioneer tweeters on the A pillar in parallel with the dash 4x6's using my Pioneer decks internal Mosfet amp to power them. It worked fine for about 5 months then one day the pioneers Amp just stopped working except the external amp powering my bazooka sub. After a lot of checking out I finally disconnected the tweeters and everything was fine.
The amp is a two channel- 600 watt that just powers the subs. I wanted to splice the tweeters into the Jensen 5 1/4's, that I have in the dash. I've seen many people splice tweeters into component speakers and they have had no problems. What about all the loaded enclosures that have subs with tweeters, that run parallel from the factory? If anyone could clear this up for me, it would be appreciated!
There are many different configurations to hook up different speakers, parallel, series, parallel+series, parallel+series+parallel and on and on. Each example ends up with the total amount of speaker resistance anywhere from say 16ohms to 0.5 ohms. The only way you could hook up two 4ohm speakers (your 5 1/4" and tweeters) is with parallel wiring: positive to positive negative to negative which will bring the speaker resistance to 2 ohms or Series wiring: pos of one speaker to neg of the other speaker and neg back to pos which would bring the resistance to 8 ohms. If you hooked up the two speakers in Series, there would also be less volume from those speakers. That's why most Amps have specs for 2ohm resistances because you get more power from amps that were designed for it. Pre made speaker enclosures have the speakers wired inside to have the final resistance at usually 4 ohms. Hope this helps.
