Should I amplify the fronts or the rears??
Old 11-18-2001 | 11:03 PM
CamaroX84's Avatar
Well, I've got a Pioneer 6300 head unit, a 280 watt Kenwood 4-channel amp, Pioneer 4x6's up front, and Pioneer 6x9's in back. I just bought a 600 watt peak sub. I don't have enough money to get a seperate amp for it. I am going to bridge the amp onto two channels. So I have two channels left. Do you guys think it would be better to run the fronts amplified and the rears off the head unit, or run the rears amplified and the fronts off the head unit? Any help would be greatly appreciated. Also, am I going to need to put bass blockers on the two speakers that run right off of the head unit? Thanks.
Old 11-18-2001 | 11:43 PM
TrueBlue91RS's Avatar
Fronts. Definitely the fronts. Just my opinion I guess, but most people will agree that the front soundstage is significantly more important for imaging. You also have to take into consideration the fact that the 4x6's are not as efficient as the 6x9's.
If you want to be sure, though, it shouldn't be too difficult to try out both setups and compare them directly. That way you can be sure of which method is right for you.
Old 11-19-2001 | 07:08 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I consider rear speakers to be worthless, so I also say front.
Opinions aside, I still say front. By amping the fronts & the sub, you'll maintain linearity between them, so you'll get a more consistant sound, and for the sake of rear fill, deck power is plenty for the 6x9s.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old 11-19-2001 | 01:21 PM
89transam's Avatar
Yes once I amped my back speakers and a sub .....it sounded like trash
Nate
Old 11-19-2001 | 06:32 PM
miked's Avatar
Only do the fronts. Many years ago I amp rear speakers. When I got rid of the rears it sounded so much better. Get a good front stage set up and at most run the rears off your deck. I'd just unhook them.
Old 11-19-2001 | 07:45 PM
CamaroX84's Avatar
Well, I just got finished screwin around with it. I have the sub and the front speakers running off of the amp and the rear speakers right off of the head unit. Sounds awesome!! Thanks for the advice.
Old 11-22-2001 | 05:05 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Amp all 4.
I did that when I had to use a 2ch amp, sounded great, just lost the front<>rear fading control.
WS6 Trans Am.
View My Ride @ thirdgen.org
Old 11-29-2001 | 11:40 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
You could use the four channels seperately, and then run the sub off of the rear channels but mono. That is to say after hooking up the rear speakers, left and right, you take the positive of the right side and negative of the left side and run them to the sub.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old 12-02-2001 | 12:07 AM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
depends on the car, i know in the 3rd gens the back speakers are hard as hell to hear, but its' good to equally amp all the speakers. in most cars, its more beneficial to amp rear speakers, because in the front the speakers are usually small, and cant move that much air anyways, so u can get more spl outta ampin the back
customblackbird
08-15-2021 10:16 PM
SiCkRs
Members Camaros
32
07-01-2018 04:53 AM
AkDrifted
08-17-2015 07:45 PM
THABADGUY
Brakes
08-11-2015 03:43 AM
Quick Reply: Should I amplify the fronts or the rears??
