Orange Illumi Wire
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Orange Illumi Wire
How do I wire up this wire from the head unit when I don't have a stock connection for it? It would be nice to have my deck dim at night, it is rather blinding.
Car: 1986 Firebird
Engine: 2.8 V6
How can you not have a stock connection for it???
Use the brown wire in the factory radio wiring harness. That goes to the car's light switch, and was used for the "Factory" clock dim. It either gets 0 volts or +12 volts. The gray wire is variable, and runs off the dash dimmer wheel. What kind of head unit do you have? You probably want to use the brown wire as a "dim" signal.
These two wires are in a connector all to themself. You know how you have the three main connectors for the radio (black, blue, and white)? Well this was a little two-wire white connector that went to the "passenger" side of the back of the factory radio.
I have a Pioneer deck. I don't have a clock.
Car: 1986 Firebird
Engine: 2.8 V6
Riiiight.. Pioneer makes many head units. Does yours have a model #? Does it even have a wire coming out of it for illumination?
And it doesn't matter if you have a clock now or not. From the factory, your car had a clock on the radio, and it would dim when the owner put the lights on.
Well, good luck. You can always paste a small piece of window tint over it.
My deck specs are in my Signature.... DEH-P77DH and yes it has an orange *illumination* wire.
