wattage over quaility
alright I am fairly new to stereos and new help choosing a new setup. I went to one of the local stereo shops and the've got an amp, earthquake(anyone heard of the is make.... the said its fairly new to the store) which is 300watts. and another shop has a kenwood 600W amp for $100 more.
anyhelp would be greatful
<font face="Verdana, Arial" size="2">Originally posted by F-BOY:
anyhelp would be greatful</font>
![](http://iroc.fbody.com/banner.jpg)
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1987 IROC-Z
with my experience, you could buy a amp that advertisies a nice amount of power.... but thats peak, and it will prolly distort like all hell.... when you buy sterio equipment, you ALMOST ALWAYS get what you pay for....
if you want to be loud and obnoxious, buy the cheap stuff... but if you want to be loud and sound good, and enjoy listening to your music, go out and pay for the good stuff... it is definately worth it.
and dont "jerry rigg" anything... make sure you do it right, because if you fry your electrical system in your car, its more than just the sterio your gonna have to replace.
jon
[This message has been edited by sunbound (edited September 20, 2001).]
jon
Okay so we got the amp situation... but for a what brand do you guys like for subs... more more suggests the better so that its not biased thnx.
And don't forget this is on a high schoolers budget
![](https://www.thirdgen.org/messgboard/smile.gif)
Same situation with subs. Your amp has more to do with how loud you get than your subs, so shoot for sound quality here, especially considering the low power that I'm guessing you'll be feeding them.
Stay away from these high-excursion subs with the big fat surrounds and huge magnets. These things can get seriously loud.... with gross amounts of power. On modestly powered systems, they will not get as loud as a more conventional style sub. Those high excursion subs have very low sensitivity ratings due to their high mass structures. Something like a JL W6 sub, an Oz 300L or any one of hundreds of more traditional, non-small box designs will generally offer higher sensitivity and still be capable of producing useful output through the capabilities of your amp.
Again, shoot for quality over quantity. A single 12" sub with an amp such as a Kicker ZR240 or Rockford 360a2 will pound hard and is capable of sounding quite good. When you get more money down the road, it's cheaper to add 1 more good sub than it is to upgrade both cheap ones.
The IROC Homepage
The IROC Homepage
Definately go with quality. I got a simple Alpine 50x2 V12 running at 2-ohms (actual output about 140w per channel), and the sound quality is outstanding through my two Infinity Kappa 10"s. Plus this setup (through a sealed enclosure in the hatch) can play painfully loud; probably not breaking any SPL records, but way more than anyone would need for SQ. The Infinity's I got only because a friend of mine sold them dirt cheap(baby on the way), but for new, I'd go JL, Kicker, or MTX.
89' Firebird Formula
Black/grey cloth
305 TPI/5 speed/3.45 rear
dual cats/PW,PL/T-tops
K&N, SLP TB booster,
SLP exhaust, Jet chip
Black/grey cloth
thanks for you input guys...
I don't need to be loud, I just want a clear sounding system. just giving that extra kick to the music
does anyone know with the right amp does Audiobahn sound anygood
[This message has been edited by F-BOY (edited September 20, 2001).]
84 l69 T/A
5 speed, 373 posi rear
comp xe262 cam
hedman hedders and y-pipe no cat edelbrock pipe and areo chamber muffler
performormer rpm intake
holey 750 vac,,tuned for the 305
accel hei w/msd 6a box
wp sr 305 heads,
stereo, 8 memphis power bass 10's,2 memphis 1000d amps,ohio generator 140 amp alt,tsunami dry cell bat,set of memphis power reference 4x6's,and a set of memphis studio 6.5's with a memphis power bass 400 amp on the highs....dbdrag comp car
84 l69 T/A
comp xe262 cam
wp sr 305 heads,
Car: No more birdy
(edited September 20, 2001).]</font>
If you have a budget and your main concern is some thing that sounds good "non competition" I can reccomend the jensen LXA300. This 300watt amp is cheap 115$ US and the specs are "very" impressive. I would say its as good or better than any name brand 300watt amp under 500$
This is the "only" Jensen component I reccomend so you might look into it.
SSC
as the others have said, you do get what you pay for, always check around on ebay they have alot of companies with overstock selling for usually half price (most have the buy it now feature), also when buying a system I personally prefer to buy matching amps and subs right now i have 2 12" mtx 3000 thunder 450w being pushed by a bridged 325w mtx pro blue thunder amp at 4 ohms (im only using 150w W/ 4ohm) it sounds good and pounds hard just because it is matching
Justin
1982 Recaro TA
Justin
1982 Recaro TA
<font face="Verdana, Arial" size="2">Originally posted by 82 recaro:
</font>
</font>
Thanks' I'll try Your E-Bay suggestion out
![](https://www.thirdgen.org/messgboard/biggrin.gif)
