How much fiber fill is too much?
I have a 1-lb. bag and decided to split it up equally between both chambers in my box. Each chamber is about .5 cu. ft., so there's 1/2 lb in each. But almost the entire thing is full of fiber fill except for one little area directly under the mounting hole for the magnet. Is this right? BTW- the subs are Infinty Kappa's, and the instructions have box recommendations from .25(?) cu. ft. to .75 cu. ft. per sub. The .75 cu. ft. looked like it had the flattest curve which is why the poly fill.
Thanks!
89' Firebird Formula
Black/grey cloth
305 TPI/5 speed/3.45 rear
dual cats/PW,PL/T-tops
K&N, SLP TB booster,
SLP exhaust, Jet chip
Thanks!
Black/grey cloth
If I recall correctly, you need about 1 lb. for each cubic foot of airspace. Therefore, you are at the right amt. When I did mine, my box was also full to the brim with the stuff, so I bet you have the right amount.
