lighting cap question???
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
I bought one of those lighting caps but my question is how do u charge it before u put it in. the instructios say use a resistor but mine never came with one. any help???
86 Z28:
L98 350
aluminum heads
T-5
235/60R15 BFgoodriches
dual 3"flowmaster exhaust
20% tint
hatch wing
2 12"kicker solos
300 watt Sony xplod amp
Sony xplod deck
K&N air filter
http://www.geocities.com/xmikex.rm/mike.html
86 Z28:
L98 350
aluminum heads
T-5
20% tint
hatch wing
2 12"kicker solos
Sony xplod deck
K&N air filter
I guess you could charge it off a battery, but to prevent draining the battery (unless the car is running) I would use a 12V power supply, such as a trickle charger. Just hook the + on the capacitor up to the + on the battery, - to -, and put the light bulb in there somewhere, in series with the capacitor...it really doesn't matter where though. So a wire goes from the battery to the light, another from the light to the capacitor, and another from the capacitor back to the battery. And once you get it charged up, make sure not to short it out...you'll get lots of fireworks.
- Mike
- Mike
just hook it up it will only spark a bit no harm done
keep in mind the last thing you hook uo will pit from the spark so use a cheap wire on a part that wont matter
also be prepared for some noise...i allmost crapped myself when i hit the connector on mine. mine made a loud boom
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
