are kicker amps 1 ohm stable?
i want to wire my 3 subs in parallel and since they are 4 ohm single voice coil subs, that should give me 1.3 ohms.... and my friend told me that kicker amps rock and they can handle that low ohm level... is that true? thanx!
1.3 ohm bridged load gives a .65 ohm load to each amp channel. That's virtually a direct short. I'd say it's probably not wise.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
kicker amps nut running 1 ohm mono? Our 2 ZR1000's in our demo car seem to handle to load just fine all day long. Granted the impulse series can't and the XS are high current "cheater" amps meant to play extremely low loads, but the ZR's do just fine.
rated to, and may be able to handle are sometimes two different things.
When Kicker says a ZR amp can go 2 ohm mono, I take that to mean that I can beat the crap out of it at 2 ohms, all day long with no ill effects. Sure, it may be able to do 1ohm for a time, but for how long ??
mike
custom 3rd gen kickpanels at http://www.lachernet.com/kickpanels
mike
<font face="Verdana, Arial" size="2">Originally posted by DJSexay:
mike
</font>
mike
</font>
raymondandretti
09-27-2015 06:43 PM
