Whoever knows CodeAlarm alarm systems in here please...
I have a codealarm system in my car installed just before I bought it. The guy who did it did a very hack job and the old owner got a partial refund instead of having it fixed. Anyway, it still does the basics like unlocking the doors/shock sensor/ignition kill. My question deals with the shock sensor. When I installed my amp and bass tube I must've moved the shock sensor or something because now it's not sensitive at all anymore. You practically have to smash the windshield to make it chirp.
Is there a way to adjust the sensitivity of the shock sensor? If so, how? Is the shock sensor separate from the main unit? I don't even have the instruction manual here so I'm flying blind. Thanks for the help.
1987 Camaro Sport Coupe LG4
700R4 with 2.73 open rear
Hypertech chip, 180* stat
L69 Dual snorkel air cleaner with K&N air filter
CK rods with B hanger
Hooker catback
Pioneer DEH-P4000, Pioneer TS-A4615 front TS-A6995 rear
Kenwood KAC-529S driving 8" Bazooka EL804 bass tube
Hooker catback
1 Post
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
I have a older code alarm And there should be a sensor that you can either turn up or down the senitivity mine is under the driver side lower dash..Maybe this will help...
Location: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Most alarms come with a separate shock sensor...you may have to locate the alarm box and follow the wires to see where it is since different installers use different places to mount it
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Performance:
Electronics:
There should be a separate shock senson mounted under the dash. A common spot is on the steering column. There's an adjustment screw on it somewhere. Don't put any money into that alarm. Code/Chapman alarms tent to crap out after two or three years. HTH
I found it and ajusted it. Thanks guys. It's done ok for me now, my problem seems to have been with the dealer who didn't have a clue. Anyway, when this one does crap out I'll probably replace it with another brand. Although I do like the 125 dB siren...
Pac J
05-17-2020 10:44 AM
[Sold] Flowmaster exhaust system
Night rider327
10-09-2015 09:25 AM
Night rider327
09-25-2015 04:47 AM
