Crossover vs amp filters
I have 2 amps and they both have low pass/high pass filters on them.
I am wondering if people find these acceptable or if electronic crossovers which are far more adjustable are preferred?
Assuming the external crossovers are preferred, what are the characteristics to look for to find a good one?
As long as you don't need options/flexibility beyond what is available on the amp crossovers, just save yourself the money and use those. There won't be an audible difference between an amp's 12dB/octave crossover and an external one. External crossovers usually offer the benefit of extra flexibility in terms of output channels and filter frequency. Many of the better ones also use steeper filters.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Another cool feature is some crossovers will boost your output signal voltage to your amps so you can get a cleaner signal and not have to turn your gains up as much to get the same output.
It depends on what kind of crossover. A passive crossover would go between the amp and speaker, but it wastes power and is not really a terribly accurate device unless it's designed in a such a way that it winds up being real inneficient. It's also non-adjustable.
An active crossover is one that manipulates the signal before it is amplified and does so with op amp circuitry so there is no signal loss. They can also be adjusted, unlike passive units. They make passive units that are designed to be used before the amp, but they're all crap.
Having a crossover boost the signal is basically worthless unless there is a very large distance between the crossover and amp.
The IROC Homepage
The IROC Homepage
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Alright, usually I just assume you know what you're talking about, but this just sounds wrong. If boosting the signal is useless, then why do a lot of good companies make line drivers? Their only function is to boost the signal voltage. Since most cars are roughly the same length from deck to trunk, I don't think the distance has a whole lot to do with it. Also, why would good decks come with a higher pre-out signal voltage? You've got a bunch of explaining to do to back up that statement man.
'91 RS 3.1
SSM SFC's
Energy Susp. Hyper-flex kit
GTA Sway bars
Clarion, Phoenix Gold, JL Audio, etc.
Quote "If you can't beat them, arrange to have them beaten."
- George Carlin
'91 RS 3.1
SSM SFC's
GTA Sway bars
- George Carlin
1. Companies make them because people buy them.
2. There are only 2 benefits to a higher level signal. The first is better noise isolation, but if your crossover is right next to your amp, it's useless. I don't know many people that mount their crossovers to their dash boards. The second is the ability to lower the noise floor of the amp. This is quite valid, but only if the crossover has a lower noise floor than the amp, which isn't real likely.
The IROC Homepage
The IROC Homepage
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
<font face="Verdana, Arial" size="2">Originally posted by Jim85IROC:
</font>
</font>
A higher voltage from a pre amp that's up front is considered a good thing, I'm not denying that. I just find it fairly useless on an external processor that gets mounted in the trunk right next to the amp. Anyway, boosting the voltage does lower the noise floor and help reject noise, but it's an absolute minimal amount. Sorta like the difference between 600 horsepower and 600.05 horsepower. With a 2 or 4 volt pre out, you're already dealing with a very clean signal, so there is only minimal room for improvement. In a competition system where judges specifically listen for any audible amount of noise, it *may* make a difference. In any type of real-world situation it's a waste of money.
A higher pre-out voltage will not make anything louder. Your amp is only going to reach a predetermined maximum output regardless of how much voltage you feed it. In order to keep the input stage of that amp from going into clipping, you need to trim the gain back on that amp. In doing so you lower the noise floor of that amp, but you in no way get any sort of additional output from it.
The IROC Homepage
The IROC Homepage
gixxer92
05-18-2017 11:20 AM
raymondandretti
09-27-2015 06:43 PM
