I GOT SOME SUBS ARE THEY GOOD?!?!?
Hey, I just bought 2 Rockford Fosgate 12" subs model # RFZ2812 I was wondering if anyone has these or has heard these subs before and how good they sound. I'm thinking of going with a Rockford Amp also because I think the Xplod 760Watt amp would blow these subs because they are 200Watt. But I dont' know about car audio at all that's why I'm posting this.
(orignally CDnAP48)
'91 Camaro RS (in readers rides)
Dark Metallic Blue
V6, 4th Gen Seats, Sony Xplod CD Player and Sony Xplod 6x9's, Kelly Charger Front Tires. Soon to come, DJSexay Kick Panels, Polk Audio Component Set, 2 Sony Xplod 12"s, Sony Xplod Amp, New Rims, New Rear Tires, Carpet, Floor Mats, Paint Job, Interior Color Change.
E-mail me for any questions or comments.
AdidasPredator15@jam.rr.com
(orignally CDnAP48)
Dark Metallic Blue
Those are rockford's entry-level subs. The ones that Circuit City and Best Buy sell during their buy one get one free deals. They're decent subs for the money. You don't have to worry too much about that Sony amp overpowering them though. Their 760 watt amp (XM-1502SX) is rated at 150 watts RMS per channel, and even that is a bit (a bunch) optimistic. It's a decent amp, but certainly not one that's going to overpower those subs.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
If I get the Sony Xplod 760 Watt amp will it make those subs sound good? If not what would you prefer... I'm going for about $200 and under....
(orignally CDnAP48)
Dark Metallic Blue
V6, 4th Gen Seats, Sony Xplod CD Player and Sony Xplod 6x9's, Kelly Charger Front Tires. Soon to come, DJSexay Kick Panels, Polk Audio Component Set, 2 Rockford Fosgate 12"
s, Rockford Fosgate Amp, New Rims, New Rear Tires, Carpet, Floor Mats, Paint Job, Interior Color Change.
http://www.geocities.com/adidaspredator21/index.html
(orignally CDnAP48)
Dark Metallic Blue
There's really not anything in the $200 and under range that's going to move those subs. Power costs money. I'd look into a Kicker ZR120, but that's going to run near $250 with the crossover.
The IROC Homepage
The IROC Homepage
So I shouldn't get the 760W Xplod Amp?
(orignally CDnAP48)
Dark Metallic Blue
(orignally CDnAP48)
Dark Metallic Blue
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
No. My buddy's got one in a (pardon my language) Hyundai, running two 10" X-Plods. He's got an X-Plod HU, 6 1/2"s, 6x9s, etc. It sounds pitifull. He's gotta turn the gain WAY UP to sound even close to my system, and that's w/ my volume halfway up. Check my sig.
He's not at all happy. I just do the "giggle-snort-giggle-snort" at him. Pisses him off!!!
Edit: BTW, that's a Punch100 that I bought back in 1991 running 2 MTX Thunder3000s. Cheap **** to, but good companies.
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
[This message has been edited by AJ_92RS (edited July 17, 2001).]
air cleaner
-B&M TransPak
-Jet Stage2 Chip
I'm gonna look at that Kicker ZR120 Amp... anyone else have any other recommendations for an amp for my subs???
(orignally CDnAP48)
Dark Metallic Blue
(orignally CDnAP48)
Dark Metallic Blue
Jim is dead on. If I had those subs, the ZR120 would be a perfect marriage. Or, well, is there a perfect marriage?
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Holley 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with Hughes 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
<font face="Verdana, Arial" size="2">Originally posted by Polecat:
</font>
</font>
1 Post
Like Jim said, those are Rockford's entry-level subwoofers. I've only had the chance to listen to just a few of them...but I think they're very good for the price.
Also, you did the right thing by buying the 8-ohm version. You can wire the two speakers in parallel, then bridge your amplifier for a little more power.
I've put in a few of those Sony amps...they do seem to put out enough power in my opinion...but they also seem to get extremely hot for some reason.
In any event, I'd say that's a half-decent amp for $200, but you can NEVER have too much power. And like Jim said, the Sony will put out its rated RMS wattage, at best. There are many other brands out there...like Kicker, Rockford, MTX, and others, which actually put out significantly MORE power than they're rated for.
db057
08-11-2015 10:11 PM
