Amp in Tri-way output mode, How can I get bass to the woofer?
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Hey all. Im running one of thoes kenwood "600 watt" amps in tri-way mode.
It's running a set of kenwood excelon 6x9's, and a 12" kenwood woofer in a ported box.
Anyhow, the amp is set for full-range sound. The woofer sounds pretty bad running while it trys to hit the highs, but if i use a crossover, it goes to the RCA before it hits the amp. What should i do to setup the woofer to get only bass? Run a bass coil?
Thanks for any suggestions!
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
Doesn't know enough about cars.
AIM: jesusathome
1986 IROC Camaro
305 TPI "LB9"
3.23 gears
AIM: jesusathome
is that amp 4 channel or 2 channl?
if the amp is only two channel you can only run either the speakers or the sub of it.
if it is 4 channel then each channel should have their own crossover... set the channel with the sub to 'Low Pass Filter' and the channel with the 6x9s to 'high pass filter'
if you are running a two channel amp with two 6x9's and one sub it will not work nor sound proper.
kev
kev
Location: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I'm not sure if you are using it, but you really should be using a head unit or EQ with separate RCA lines for both your 6x9's and your sub. This way the proper freqs go to the right speakers regardless of what your bandpass filter settings are at.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Performance:
Electronics:
TMZIrocZ350
10-07-2015 12:09 PM
raymondandretti
09-27-2015 06:43 PM
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
