Kicker ZR240 enough to power....
I've built my own sealed enclosure to house a pair of Kicker S10L7's (10" solobaric's) and I was planning on having a single ZR240 power them but now I'm thinking that these subs have a huge power rating on them and this amp won't be enough to get the job done. Will it be sufficient? any suggestions? I'd like to stay with Kicker all around.
~Luke a.k.a. pianiy
'91 Firebird :: 305/TBI(L03)/700R4/T-tops ::
Mods: Catco high flow cat - B&M Shift kit - TA tail light conversion - K&N - MacEwen white faced guages
Stereo: Pioneer DEH-P8200R - Pioneer 6x9's - Kenwood 8" Tube
'87 Firebird :: LB8/700R4/220K :: R.I.P. ::
Firebird parts - Got an '80 Firebird for sale too
Moderator of tranny board over at TransAmGTA.com
[This message has been edited by pianiy (edited June 25, 2001).]
~Luke a.k.a. pianiy
The subs can handle more, but when driving a 2 ohm bridged load (i.e. a pair of 4 ohm subs paralleled) those amps can deliver a TON of power. They have a different power supply than the 360 and 600, so running into 2 ohms bridged, they actually deliver as much power as the 360. Powerful, powerful amp, especially for $300. To me it's the best bargain out there for sub amps.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Jim is totally correct. The ZR240 will be enough to power the subs. The woofers can and will handle alot more in the proper vented enclosure. You can check out different enclosure recommendations on our website at www.kicker.com
Good luck!
Good luck!
Baron
Car Audio
07-27-2001 03:04 PM
