Cutting 3/4" MDF
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Cutting 3/4" MDF
What's the fastest way of cutting it?? Best way of cutting it? Can I use a jigsaw? What kind of blade on a 7 1/4" circular saw???
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Not trying to step on any toes, but I've found that using a metal blade in the jigsaw makes the most accurate cuts.
The finer teeth allow more maneuvering needed for cutting holes, curves, etc. Wood blades seem to want to grab the wood, and bind up more.
One thing that my friend and I found out, even though I told him that it wouldn't work; DON'T try using a RotoZip.![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
I told him that MDF is NOT like real wood. It's a lot harder. But he just got this RotoZip and had to use it.![Roll Eyes (Sarcastic)](https://www.thirdgen.org/forums/images/smilies/rolleyes.gif)
Snapped about 3 of those blades before he finally admitted I was right.
AJ
AJ
in my opinion the best way to cut mdf is on a table saw because you will get the most accurate cut that way. but not everyone likes to put a whole sheet up on the saw (its really not that easy) and not everyone has a table saw. a piece of advice if you are using a circular saw is to cut long strips and use a fence. for example...if you need 7 pieces that will be 11x8 inches, cut a long 11 inch strip and make them out of the one piece, you will have more uniform cuts and everything will fit together nicely. (as opposed to making 7 different 11" cuts...one might come out to be 10 and 15/16 and another might be 11 and 1/8 just cause that **** always seems to happen...)
I hate table saws. I can't ever cut straight with one. The wood always drifts on me. That's not to say that others don't have vastly better luck than me however.
But, when I first started with a circular saw, I would clamp a metal straight edge to the wood to guide the saw. The result was a perfectly straight line. I've long-since discarded the straight edge in favor for free-hand cuts. After you spend enough time with a saw, you get good enough to leave 1/2 of a pencil line on your cuts.
Thanks guys! Well I think I need practice w/ a circular saw, but how easy is it to work with a jigsaw? Can I make all of my cuts with it? (Straight and circular)
I'd avoid jig saws for straight cuts. Stick to the circular saw, and just use the jig saw for the small, intricate cuts and other stuff that you can't easily do with the circular saw. Once you get good, you can cut 1/2 a pencil line with a jig saw too, but it's a lot harder and it's a lot slower.
