Front Speaker Crackle
Well I just installed my new Pioneer TS-A4612 4X6's into my dash today perfect fit so that was nice. But even before when I turned the volume and bass up to much the left speaker would crackle some. I know its not the speakers because the stockers and the new pioneers do this? Whats the probaly could it be the wiring.
In a few day I'm going to pick up so rockford fosgate 6X9's for sale at best buy for 60 bucks seems pretty good with a 150 max watts and 75 rms. they're 2 ways too. Anywayz anyone know what the crackle is from and are the fosgate 6x9s good? Thanx
where does that front speaker wire go cuz it looks hard as h*ll to get to down there and find the culprit of the problem. any suggestions or other ideas?
I was planning on doing that to the rear I guess I'll do it to the front too. whats the best route to goto the fronts? the way the stock ones do it or is there a better way? thanx
when I ran the wire for my quick panels I rant them fromt the deck and tucked it up under the dash. if you take off you dash pad you'll see spots that you can run em, I'd say from the deck to under the dash(and on my car) there was a 1in square spot to run it up into the dash speakers. It wasn't that hard when I did it, just use a stiff wire and attach your speaker wire to the back of it. that made it easy for me man! Later
ambainb
04-25-2016 09:21 PM
db057
08-11-2015 10:11 PM
