New deck wiring
Old 01-30-2002 | 04:15 AM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
New deck wiring
I'm in the process of installing a New Kenwood MP3 player and have run into a problem. I wired it all up and the first question I have is for the deck illumination. According to my haynes manual the factory deck had 2 wires that handled illumination duties, a brown wire that was for DIM Signal and a grey wire that was for panel light. The New deck has only 1 wire to handle this duty. I went for the brown wire, was that the right choice? I fired it up and everything was working ok until I turned up the volume, then the deck cuts out and flashes OFF CODE, then comes back on and does the same thing untile the volume is turned right down.The kenwood book has no explaination of the OFF CODE that flashes before the deck cuts out. Is the deck screwed up or do I have something wired wrong?
mustangman65_79
04-14-2017 05:37 PM
mustangman65_79
Car Audio
09-30-2015 09:37 PM
Bryan F
08-27-2015 07:28 AM
zayne0
08-24-2015 07:22 PM
rithsleeper
08-11-2015 07:55 AM
Quick Reply: New deck wiring
