My subs don't hit as hard as they should
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
I have a set of 12" soundstream SPL's powered by Lanzar Vibe 430 amp. They are in phase yes. This is a 4 channel amp. Does anybody know how to wire this amp to make these speakers bump.
1986 CAMARO Z28 ->
151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, B&M Ripper shifter, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframe connectors, all bushings are urethane, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.32@ 106.4MPH 3300lbs less driver and speakers Next mods-> Extreme Energy 268 cam, Holley street dom intake, ported heads.
1987 TRANS AM ->
73,000 miles, 305TPI, auto, gutted air box, gutted cat.
1986 CAMARO Z28 ->
1987 TRANS AM ->
Well...If you don't know the basics of hooking it up, you probably shouldn't.
I can give you the basics.
1. A four channel amp isn't gonna do you any good for 2 subs if it isn't bridgable into two channels.
2. If the amp doesn't have a crossover(seperates the frequency of sound)you need to get one, pumping the highs into subs is not going to sound good and its a waste of power. Get a crossover so you can amp just the low end to the subs.
3.Put the subs in a sealed or ported box. They wont bump unless they have a confined volume of air to push around.
4. Make sure your amp wire from the battery is a low guage wire, so it the amp can draw sufficient power.
Hooking it up
1. There should be a wire directly from the battery to the amp. Make sure to put in an in line fuse.
2. Pull out the head unit and check for a wire that is "hot" when the sterio is on and goes off when the sterio is off. This is called the led wire I think. It just tells the amp to go on only when the sterio is on. Stop the amp from draining your battery.
3. The Ground. If you take off the back panel in the trunk, You can find a ground used by the hatch motor assembly. Or you can drill and make your own.
4.Wire the speakers. Use a low gage wire, or RCA cords, if you can.
I can't think of anything else you would tell someome about hooking up subs in a car, Other than, that I found, Cheap things sound cheap.
Hooking it up
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
I can either run 4ohms 2X200rms or 2 ohms 4X175rms. Is there any way to run
it 2 ohms into just my subs?
My system meets all the requirements of that you listed. The amp is bridged to 4 ohms at 2X400watts max. It has a built in crossover. I run 4 gauge wire. I also have a sealed box.
1986 CAMARO Z28 ->
1987 TRANS AM ->
1986 CAMARO Z28 ->
1987 TRANS AM ->
Actually it's power rating is 2 x 450 Watts Peak @ 4 Ohms Bridged. Plenty enough to power your subs. How do you have them wired? Is the amp bridged? Bridge each side of the amp so you have 2 channels and then just run one sub off each of the channels.
<marquee>'87 Trans Am:
(Engine)305 TPI,180 Degree Thermostat,JET Fan Switch,TB Bypass,Accel 300+ 8.8 Racing Wires,Accel Super Coil,Bosch Platinium Plugs,Custom Ram Air with K&N,Removed Emissions Equipment & Cat.(Stereo)Full Kenwood Excelon System Member at kyfbodies.org</marquee>
[This message has been edited by jobryan26 (edited May 13, 2001).]
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
I have it bridged. That's about all I know.
1986 CAMARO Z28 ->
1987 TRANS AM ->
1986 CAMARO Z28 ->
1987 TRANS AM ->
waht kind of sound are you trying to get?
the Soundstream SPL subs were designed for competetion only and don't have the greatest sound quality, playing best at 60hz or below.
most music isn't recorded that low, so they may not be the right subs for your system.
also you said you have a sealed box, but didn't mention the size, you may have too small or too large of a box. the SPLMules want 0.83 cubic ft with the sub in, so 1cubic ft box is called for.
given the amp that you've got, I'd run alpine R Type 12's or JLaudio 12w3-d4's
89: stock 305TBI, strut tower brace, MSD6AL, k&n filters,
stripes by AutoTrim Design,
optima wheels,
Kenwood kdcx615s deck,
MBQuart dkd146 4x6,
MBQuart Q series components in custom plates in rear pillars
2 JLAudio 500/2 sub amps
2 JLAudio 300/2 mid/high amps
2 12" soundstream SPLMules in 4 cubic ft box
audiosource 3.1 control center/EQ
154.1db in 1-2 street class
GO TEAM CAR TOYS!!!!
optima wheels,
MBQuart dkd146 4x6,
92camaroJoe
08-13-2015 06:07 AM
db057
08-11-2015 10:11 PM
