System for under $1000
Can someone name all the componets of a not so bad system that equals less than $1000, i want something that hits hard, but that kill my wallet, because i'm trying to save up for my 3.1 to 5.7 swap, thanks.
------------------[*]191(3.1)V6 1992 Pontiac Firebird[*]K&N fiter with custom Ram air[*]Flowmaster Exhaust w/ 3" tips[*]Pioneer reciver[*]kenwood 4x6's[*]sony xplod 6x9's[*]1 kenwood 12" powered by a 300 watt jenson amp[*]-----------[*]Best 1/4 ET as of Now[*]17.7110 @76.01www.geocities.com/my_92firebird
brand new equipment...
rockford fosgate bd1000a1 $385
12-15' Power Dvc $185
kick *** for $600
if you dont like rockford, try kicker...
[This message has been edited by KlayBuRn (edited April 07, 2001).]
kick *** for $600
Expect to pay substantially more if you want a warranty.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Do you want to replace everything in your system, or just amp and subs?
IF you want to replace everything, start out with a
Used Eclipse CD player $250
Infinity 4x6's $75
Infinity 6x9's $105
Audiobahn 500 watt $350
JL Audio 12w1's $200.
Box $75-80 (do it your self for less)
That is just a little above $1000 ($1060) but you are talking about a total system there. That Audiobahn amp is more than enough for those subs, and you may want to consider getting a multi channel amp to power your highs better.
Chris
Infinity 4x6's $75
Infinity 6x9's $105
Chris
AutoTek Mean Machine
MX-250 450x1 @ 2 Ohm $326.25
JL Audio 12W0 4 ohm
$93.75 each
DEH-P7300 45x4 CD Deck w/Organic EL Display
$309.88
Installation
$45.00
Enclosure
no more then 40 bux
Approx. Total: $910.00
Leaves money for shipping and what ever else comes up.
[This message has been edited by dallasiroc (edited April 09, 2001).]
JL Audio 12W0 4 ohm
$93.75 each
$309.88
Installation
$45.00
Enclosure
no more then 40 bux
Car: 99 F350 Dually 97 Chevy Venture 97 Honda Accord 89 Mercedes Benz 190 1987 TRANS AM GTA
Engine: Brand new 350 Crate motor
Transmission: Beefed up 700R4
I can come up with a nice package deal that will save you hundreds. Just let me know what you like.
Check me out for Hott DEALS on all of yuor audio needs Both home and car. Mobile video is also available!
http://www.geocities.com/nucarsounds
Location: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Hits hard = Good amps = $$$$$
You can get a decent head unit, CD-changer, and speakers for under $500. Unless you get a sweet deal, the amps will make you or break you. You also have to consider installation cost (parts/labor). Stay away from used amps unless you KNOW who you are buying them from. Just my $.02
92 Camaro RS LO3, 5-spd, T-tops
Performance:
SLP 1 3/4" Headers (Coated by Paul Barry Motorsports), Flowmaster Catback Exhaust, Fastchip Performance PROM, Centerforce Dual Friction Clutch, Xact 8mm wires, Open Air Element w/K&N Filter, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, Edelbrock performer intake
Performance:
Electronics:
i know how to install, i've installed for many people, just looking for ideas, kind of getting out of car audio, but still know alot, just seeing what some peoples different opiouns are.
I disagree with dallasIroc on this one.. if you are going to spend $350 on a deck then you MUST get a good quality one.. Pioneer only has one good deck as far as features go and that one is more than $500 alone.. The 7200 doesn't even have High volt pre outs. High volt preouts will allow you to turn your amps gains down and not have to have the volume all the way up on the headunit. With that deck I had to have my gains cranked and then the deck still didn't max out my subs. The speakers that were ran off the deck distorted terribly because they had to be turned up this high.. I would recommend either a clarion or an Alpine deck (maybe even Kenwood) if you are going to spend $350 on one.. Lets not forget about the prices of amp install kits! Those can run $100 for a quality one. Your subs will sound alot better if you have a good quality amp install kit than if you install it all ghetto..
This is the best I can do for $1000, and this is with the "matrix audio 1 year warranty"... If you want a full manufacturers warranty you'll probly be spending about $500 to $600 more..
Lightning audio 4 gauge amp install kit: $75
2 Rockford Fosgate 12" HE2 woofers: $260
Clarion DRX-6675z : $220
Cadence A5HC (600x1):$300
Polk AUdio 4x6"S: $60
Rockford Fosgate 6x9"s: $80
subtotal : $994
Heres two more things to keep in mind:
Enclosure for subs: $40 if you can build, $100 for Prefab, $200-$400 for custom..
Wiring harness and Kit: ~$20
That should sound pretty decent...
subtotal : $994
I completely forgot about Cadence. They make a fantastic amp as well. You could also look to Eclipse for a nice radio, but you're going to spend a little more. Car audio is just like hot-rodding your car. You have a price range in mind, and then you see something that , for just a little more, you can get, but then after you get that, your other components won't be up to par. And endless cycle....
Chris
Chris
Pioneer DEH P77D - $250
Boston Acustics FX 4X6's - $80
Boston Acustics FX 6X9's - $140
Soundstream Angina 200Watt RMS Sub Amp - $140
JL Audio 10W-3 D-4 - $145
Qlogic 10" Tube Enclosure - $120
12" Quality RCA Cable - $20
Quality Amp instal Kit - $30
Total - 925 + Shipping
This will give you a damn nice system.
<font face="Verdana, Arial" size="2">Originally posted by T/A Man:
</font>
</font>
I would go with at least 12' rca cable
www.350iroc-z.com
u want somethin hittin hard? this is what i got.
jvc el kamillion cd player -paid 325 with warrenty
2 12 in reactors,aluminum and 600 watt a piece, i paid 20 gf paid the rest which was bout 70 or 80 bux, got em of ebay
600 watt legacy amp-60 bux
and a big *** box for my 12's for free my result? a phat *** hard *** hittin system
The above post is what you want to stay away from. Those reactor subs are total crap, although they can sound decent for awhile. The legacy amps are total junk.
Chris
Chris
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I just bought a JVC KD-LX10 on uBid.com for
$165. Later I saw one go for $141.;-P It's the one that turns black when the car is off. All the specs are great to. If you look there for other things, you could get them all cheap. The JVC I bought was listed in Crutchfield for $279. Plus I still got a warranty. They got Fosgate, Pioneer, Alpine, etc. at uBid.com. Wish I would of found it a while ago.
Car: 1986 Firebird
Engine: 2.8 V6
Here's my shot, assuming you keep your radio...
Bass: Total = $350
...Amp = MTX Road Thunder RT2200, $150 -- 200x1 bridged
...Sub (with enclosure)= MTX T612, $200 -- 12" sub, 250 RMS
Interior: $380
...Amp = Pioneer GM-X354, $180 -- 35x4, with high-pass filters
...Front = Pioneer TS-A4615, $100 -- 4x6, 20watt RMS
...Rear = Pioneer TS-A6975, $100 -- 6x9, 40watt RMS
Power wiring: $120
...Battery to dist block = Basic 4ga wire, red jacket, 20 feet = $25
...Dist block to amps = Basic 8ga wire, red jacket, 10 feet = $6
...Amps to ground = Basic 8ga wire, black jacket, 10 feet = $6
...Dist block = Rockford Fosgate RP7060, 4ga in, two 8ga out, $27
...Battery post = Rockford Fosg RP8200, side mount post, $6
...Battery ring = Rockford RP8041, 4ga platinum w/set screw, $22
...Ground rings = Rockford RP6221, 8ga rt-angle ground terminals, two packs for $18
...Amp rings = Rockford RP6804, 8ga crimp spades, two packs for $8
RCA's of your choice: $60
All that for $910... prices are from Crutchfield. You can probably get better prices locally, but Crutchfield has that 4-payment plan (so you don't get kicked in the stomach all at once)!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Bass: Total = $350
Interior: $380
Power wiring: $120
reactors dont suck, did u have any to expierence? if u didnt then dont talk no shyt, my speakers are all aluminum, and trust me when i say they hit hard, they make the ground vibrate and the car shake, mabe im not rich like u and have all sony or what ever u have system but i built my self a hard hitin low budjet system
Not rich at all, I am married, have only a high school diploma and a few certifications, and I do not own any Sony car audio equipment. In fact my PPI/Eclipse/ Alpine/ Infinity system cost me less than $800, so I think I know a little bit about building a system, and can, therefore, talk "shyt".
Your reactor subs are NOT aluminum, they are chrome plated. They aren't a bad deal at all, they just aren't musical and have what we like to call Ghetto bass. They are limited in the fact that they only play certain frequencies well, and bottom out very easily if you put any power to them. And yes, I have owned a pair. Four of them infact. Their strong points are that they are cheap, durable, and don't require a lot of power. But the original post stated that he wants a system for under $1000, so I'm guessing the close we get to that dollar amount, the better his system is going to sound (in most cases). If he wants clean, musical bass, reactors are not the way to go.
No offense, and I apologize for the harshness of my last post. It was a little rude.
Thanks,
Chris
Thanks,
Chris
which model subs do u have? mine are aluminum , im talkin bout the speaker were the music comes out that part is aluminum,if u heard my system u would feel it vibreate, what size amp do u have? my speakers have very good bass hittin action,if u find me a link or what ever for yur old reactors id like to c which 1's u had.once i get money im gettin the square kickers, probly 2 12's and a 760 watt exploid amp
I had the PPI 1400. I traded it for an engine and transmission for my firebird. Trust me on this one. The reactors are not aluminum, post a pic or a model number or something. The are very few companies that make aluminum subs, and reactor is not one of them. I had a set of 12's and I installed 4 10's in a friend's car. The speaker cone is very reflective right? And it flexes pretty well, it is the Chrome coated poly-something or other cone.
eclipse head 225
kickpanel 100
infinity component 135
2 15" box 150
rf amps 200.4 and 500.2 300
2 jl 15w3 300
take off the kickpanel and component speaker for under 1000$
kickpanel 100
2 15" box 150
2 jl 15w3 300
