Power Antenna - Up but not down
'89 RS here - my power antenna has just recently started refusing to go down, and the motor is running constantly when the engine is off. My first thought was a broken cable, but but the kicker is when I have pushed the antenna down, if I start the engine it will go back up! I can also only push it down when the engine is off - when the car is running it's locked in the 'up' position. To my knowledge the cable runs both up and down functions, so I assume this can't be it - so any thoughts as to what it could be?
The antenna got bent slightly a couple of years ago, but this hasn't been a problem up until now. I've had to pull the ACC fuse to stop the motor running for now, but it'd be good to know what exactly is wrong!
Re: Power Antenna - Up but not down
The cable does run both up and down. Last two times I had one break the cable broke going up and it got stuck that way, Probably needs a rebuild. I rebuilt mine with a NOS cable and it broke again the next year I just rebuilt again with a steel cable version from ecklers
Location: Franklin, KY near Beech Bend Raceway, Corvette Plant and Museum.
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Do you have a link or part number for this Ecklers steel cable mast?
That has a steel cable instead of plastic? In the picture it looks plastic unless that is a sleeve or coating on it.
Says 1982 to 1988 Firebird. I didn't know there was a different power antenna over the years. All the ones I've had to replace or rebuild have been on 1989 and up so far.
That is the exact one I ordered for my 84 firebird it came with a steel cable. Make sure you put in your year for correct application
Airwolfe (08-06-2024)
Axle/Gears: 10 Bolt 2.73 Open
I had a gentlemen rebuild mine for me. Some of the R&R details are HERE.
His contact info:
Barney Eaton
512-869-5114
His contact info:
Barney Eaton
512-869-5114
