Stereo interference on a Radar Detector
Car: 1986 Z28
Transmission: 700-R4
Has anyone ever had problems with a radar detector being set off by their stereo? I just tried the Uniden 6599 that I was complaining about a few weeks back in a different vehicle, and there were no problems. I'm thinking that maybe I've developed some sort of vortex similar to the Bermuda Triangle within the cabin of my car that sets the detector off. That's all I've got. I've tried to think of other reasons without any luck. Comments? Suggestions? PLEASE!!!
1986 Camaro Z28
White w/ T-tops
Tinted Rear Window
ENGINE
305 H-code
Gasket-matched heads and intake, ported and polished
Comp Cams 224 @.050
.472 lift I/E
Dual Snorkel Air Cleaner w/ K&N filter
Accel 8.8mm wires
TRANNY
700-R4 w/custom built 3000 stall converter
tranny cooler
EXHAUST
Flowtech Headers
No cat
Dynomax muffler
STEREO
Alpine CDA-855
Kenwood 4X6's, 6X9's
MTX 4240 amp
2 Sony 12" X-Plod's
Alpine 8440 alarm
Uniden 6599 Radar Detector
Take 'er easy, and if
she's easy, take 'er twice!!!
1986 Camaro Z28
White w/ T-tops
Tinted Rear Window
ENGINE
305 H-code
Comp Cams 224 @.050
.472 lift I/E
Accel 8.8mm wires
TRANNY
tranny cooler
EXHAUST
Flowtech Headers
No cat
Dynomax muffler
STEREO
Alpine CDA-855
MTX 4240 amp
2 Sony 12" X-Plod's
Alpine 8440 alarm
Location: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Your stereo shouldn't be causing interference because the radar detector's frequency band is out of range. I've had several detectors in cars with loud systems and never had any interference from sound.
This is just a WAG...but maybe your system is causing a noticeable power drain which is affecting your detector. Does it act up only when your stereo is turned up or all the time?
92 Camaro RS LO3, 5-spd, T-tops
Performance:
SLP 1 3/4" Headers (Coated by Paul Barry Motorsports), Flowmaster Catback Exhaust, Fastchip Performance PROM, Centerforce Dual Friction Clutch, Xact 8mm wires, Open Air Element w/K&N Filter, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, Edelbrock performer intake
Performance:
Electronics:
Car: 1986 Z28
It seems to me that it acts up no matter what I do. Even when I had my stereo off, it would still go nuts. I have been having problems with my charging system, though. I'm sure my battery is weak, and I think my alternator is on its last leg. Would fluctuating current screw it up?
Most definitely! Try plugging something else in to your connector (cigarette lighter) and see how it works. Also check the wiring to make sure its good. If you have a voltmeter, check the output while you are driving.
Unless you have other problems with your electricity, I wouldn't start replacing the battery or alternator just yet
Car: 1986 Firebird
Engine: 2.8 V6
If I leave my Uniden on with the car off, when I start the car up again, the power drain from the starter causes the radar detector to reset. I'd bet that's your problem. Either that, or the vibration from the stereo is affecting your cig lighter connection, and vibrating it loose.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
