AudioBahn Sound Q sub vs Infinity Perfect
does anyone have these? are they any good? does an Audiobahn ALUM10X Sound Q Subwoofer beat out an Infinity Kappa Perfect 10? Thank you
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
first off i dont have any of those, but my cousin is into showing his s-10 and has heard these subs. he said that the audiobaun alum subs are pretty good. he said the infinity subs are not the best subs, and that he would go with the audiobauns. hope that helps.
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
I too would go with the ALUM subs. They are some of Audiobahns best sounding subs. You won't be dissapointed.
-Matt
-Matt
I'm kinda surprised because while I haven't heard the Q's most of the other Audiobahn's that I've heard I didn't like them that much. While with the Perfects I think there could be a power issue depending on the amp your using.
your right, the lower end audiobaun subs dont sound the best, but then again, whose low end subs sound good (except JL audio) but the alum subs can handle a hole lot more power and are suppose to be more responsive than the perfects. plus the high power handling of the alums (i think 900 w rms) should answer all your deffning sound needs while sounding good. they also look sweet to!
I am not sure how the 10's sound but I run 2 12" Infinity Kappa Perfects in my camaro and would run nothing else. They are so sweet sounding, they may not hit as hard as some other subs out there but if you want sq then you gotta go perfect.
84 TA NV
09-06-2015 08:02 PM
