What 4x6,6x9 amp combo to get?
I've decided not to get componets in kick pannels, because they cost to much, and i don't want to spend alot on my stereo, because in a year and a half, i'm getting a new Trans am. Which 4x6's and 6x9's do you recomend,i know everyone ask, but i need to know, because i plan on going out and listening and buying them this weekend, i know i need to listen to them, and figure out which ones i like, but i need to know what names are good and don't warp or blow, when you put alittle bit of power into them, also what 4 channel amp should i use to power them with, i forsure need to power them with an amp, because i'm getting 3 JL 12w6's, and an alipine 1500 watt V12, so i need to have the highs and mids, keep up with the lows. haha, i said i don't want to spend alot of money, on a system, haha(3 JL 12w6's) any infomation will help, thanks.
191(3.1)V6 1992 Pontiac Firebird,K&N drop in filter, bosch patinum spark plugs, Pioneer reciver, kenwood 4x6's, sony xplod 6x9's, two kenwood tornado 12's with a 300 watt jenson running them, check it out at www.geocities.com/my_92firebird
are carion amps good for running main speakers, i heard they are.
------------------[*]191(3.1)V6 1992 Pontiac Firebird[*]K&N filter with no air box(open air)[*]bosch patinum spark plugs[*]Pioneer reciver[*]kenwood 4x6's[*]sony xplod 6x9's[*]much more engine and stereo mods to come!!!...., when i get some damn money. www.geocities.com/my_92firebird
Go with the infinity kappa series for your speakers. Get the 4x6 plate speaker and the 3 way 6x9. I love the sound of these speakers better than any others I've heard.
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, Turbo 350 tranny with 2500 stall.
82 Camaro:
Well the first question is how much money? mcconahay37 has a good recommendation if you don't mind spending about $300.00. The Infinity speakers sound good and have excellent mid and high's but they lack in the low end dept. just a little and require some power to get the good sound quaility they were built to provide. I recommend atleast 50watts per channel. If you have Subs this is the way to go. If you don't want to spend that much I would look into some speakers that will play a little lower.
'87 Trans Am
305 TPI:
160 Degree Theremostat
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Spark Plugs
Custom Ram Air with K&N
'87 Trans Am
305 TPI:
Accel Super Coil
Bosch Spark Plugs
Well, if oyu plan on getting a new trans-am, I'd say that is a reason to get a 6 1/2" component set in kickpanels. The 4th gen cars take 6 1/2" separates. You would be ditching the 4x6's and 6x9's.
I know where you can get decent kicks at a good price !
mike
custom 3rd gen kickpanels at http://www.lachernet.com/kickpanels
mike
Car: 1987 Firebird Formula
Engine: 305 LG4
I've got boston accoustic 4x6 plates up front and eclipse 6x9 and i think they sound great.Cost about $325 for all four.No amp yet but my deck powers them pretty good.
1987 Firebird Formula LG4,700R4,WS6,2.73 open rear
Current Mods:Flowmaster 3in. American Thunder cat-back,3in. Catco converter,L69 dual snorkel,K&N filter,roof console,Pioneer 1.5din cd player,BostonAccoustics 4x6plates,eclipse 6x9
ComingSoon! 350 crate motor(caprice),SLP coated 1 5/8 headers,edelbrock intake,edelbrock aluminum water pump
raymondandretti
09-27-2015 07:43 PM
