Will this changer hook up to my Bose unit?
Hi guys.
My friend just told me he had his old 10 dosc changer laying around and that we can throw it in my car if I want, so of course I said sure cause it beats the discman I got in there now!![](https://www.thirdgen.org/messgboard/smile.gif)
Question is....
I have a '88 Camaro with the Bose system and the disc changer is the kind that hooks into the the stock tape deck and plays through the FM station. (sorry I forget the term) So will this work on the Bose system and also can anyone give simple instructions on how to do it?
He no longer has the instruction.
*note: this is just a temporary setup until I can build a real system, I know it is hella lame, but it beats tapes or the discman, and its free.
Tim Currie
1988 IROC-Z[*]5.7 L[*]T-Tops[*]Posi
Ported plenum, Ram air, Airfoil, MSD Superconductors cap/rotor coil.
AIM- TCurrie1
ICQ- 67616089
ctimmy@thegrid.net
The Score
6/0
"Steer with the rear wheels" - My '68 BB driving boss
Self-proclamied Creator of the All-Powerful Nor-Cal crew.
Question is....
Tim Currie
AIM- TCurrie1
ICQ- 67616089
ctimmy@thegrid.net
The Score
6/0
its called an FM Modulated CDchanger, i got one mounted in the little rear tool box in the hatch...
i forget how too hook one of them ****s up, you gotta find the remote wire to the radio and all this other bull****.. its pretty much common sense though, ask Jim85Iroc.. he helped me with mine
kev
kev
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Um, maybe if you'd give us a little more information, like what brand is it?
Basically, the big DIN cables can only be plugged in one way, and the same goes for the antenna jacks.
There should be three plain wires too. Yellow gets constant power, red gets switched power, black is ground. I usually hook the red up to the factory deck's power antenna lead, so the changer turns on and off with the radio.
On the sides of the changer, there are little adjustment levers or *****. These are for setting the unit up for vertical or horizontal mounting; if you set them wrong it will skip a lot.
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
I have an FM modulated Sanyo disc changer in my Jeep. I was pretty skeptical about the idea of running a changer like that instead of the direct variety but the performance impressed me. The sound quality is no different from a regular CD changer and the romte looks pretty cool at night.
'88 IROC 305 TPI
Crappy 700R4 slushbox
Gutted airboxes
180 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel (gotta luv it)
Ram-air setup coming soon
Flowmaster muffler (puke)
Taylor SpiroPro wires
Accel cap and rotor
Ported plenum
Kills: '94 Z28, Olds Aurora V8, bunch of Mustangs, T-birds, ricers, and others who assumed a 12 year-old car would be too slow.
'88 IROC 305 TPI
Gutted airboxes
180 degree T-stat
Accel cap and rotor
Ported plenum
Z28/ZR1
10-23-2015 01:04 PM
