Alpine MRV 1000
1 Post
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Alpine MRV 1000
How many watts is this thing capable of putting out? I read in a catolog from Alpine that it's something like 1600 watts @ 2 Ohms. I know that it's stable at 2 Ohms only in stereo, so this would lead me to believe that it's 800 watts per channel in stereo at 2 Ohms? I had it pumping two MTX Thunder 3000 10" subs, and it way over powered them. The funny thing was that the amps input was under half. Does anyone know what this thing can power?
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
I've seen this amp in a '94 MX6 powering 2 Boston Pro Series 12s...this thing can literally power anything. I thought it was 750x2 at 4 ohm...but I could be wrong.
Check it out at www.alpine1.com
Jason E
'89 Camaro RS 2.8
Hypertech chip/K&N filters/Accel 8.8 wires,coil/RapidFires
Eclipse CD and 100x4 amp/Boston plates and 6x9s
JasonEE98 on AOL IM
"I feed my car plenty of rice...keeps it healthy!!"
Jason E
'89 Camaro RS 2.8
JasonEE98 on AOL IM
i don know of what that amp puts out b/c i don have it where i work but u guys are estimating a little high. the MRV-707 which i have in my car is 225X2 or 600X1, and the MRV-1507 is 450X2 or 1500X1. now the only thing is that alpne rates at 12 volts, and ur car battery runs at about 14 volts, which means they put out abotu 1/3 more power. but ur MRV-1000 should put out some where in the middle of 225X2 and 450X2 at 4 ohms.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
The MVR-1000 is offically 100x2 RMS @ 12v. In a car audio mag test, it was almost 300 RMS @ 2 ohms stereo, 14.4v. Bridged at 4 omhs, 14.4v, it was 600 watts RMS.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
-Justin-
1 Post
Thank you much!!!
