1.5 Din CD /FM deck
1.5 Din CD /FM deck
can anyone recommend a 1.5 din cd player for around $200 that is also good quality??? i don't have any amps or anything, just a stock pioneer cassette deck that sounds pretty good and i want to upgrade to play cds.
thanks in advance!
thanks in advance!
No. There aren't any 1.5 din units that cheap except for Jensen and Audiovox, which are both totally useless. You're going to have to either cough up more dough, or go with a standard single din radio.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
1 Post
Car: 1992 RS
Engine: 406 Stealth Ram
Try the Pioneer DEH-P47DH. You can get it REAL cheap here: www.sbhcorp.com . My sister got the 77DH from them, and it arrived in a few days, total was $238.xx. Thr 47DH is nder 200 bucks.
cool, thanks for the info...i was reading the description on the DEH-P77DH and it reads "Playback Compatible with Digital Audio CD-R (when disc is finalized)" anyone know what this line may mean?
It means if you burn a cd on your computer, as long as you close the session it will play. Most cd players will play CDRs though.
The IROC Homepage
The IROC Homepage
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Location: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I really don't recommend a 1.5 din head unit. The only decent aftermarket models I've seen are from Pioneer....and they look pretty lame to me when compared to the newer single din units available. For a new look you may consider utilizing the large empty space under the dashboard on the passenger side.
92 Camaro RS LO3, 5-spd, T-tops
Mechanics:
Open Air Element w/K&N Filter, Flowmaster 3" Cat-back Exhaust, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?, Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-90 Amps powering 2 12" Pro Red subs and 4 Infiniti speakers.
NEXT UP: SLP 1 3/4" Headers/Y-pipe, Centerforce Dual Friction Clutch kit
Mechanics:
Electronics:
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
[This message has been edited by Justins86bird (edited October 31, 2000).]
thanks again for the info. i wanted to go with a 1.5 din cd player to fill the hole where he factory unit was installed. if i went with a single din unit the mount kit would look like crap, i know it's already been done and i'm not happy with the job they did. if i went with putting the stereo under the passenger side dash, what would i do with the huge hole where the stereo was to be put?
1 Post
Car: 1992 RS
Actually, the MSRP for the CDA-855 is right at $500.00, I payed 460.00 for mine. Should be interesting when I get around to putting it in. I don't recall what the lower version was priced at from Alpine though.
Car: 85 Z
Engine: Edelbrock Injected 350
Axle/Gears: 3:42 LS1 Posi
Alpine offers 2 different 1.5 din models. They are a little expensive but they look much nicer in place and most din recievers. I've had my D855 in since January and it's been a great investment. My only complaint is that it doesn't have 3 sets of preouts. The face itself is very cool. It's got a graphic equalizer with different settings and black out (for when you want no display). It does seem a little under powered but most people have amps, so that's not that big of an issue. If you want to get a 1.5 din I would say get either the alpine D852 or D855. You can find the D855 at various places for about $400, the D852 is usually about $50 less. Hope this helped.
Car: 1998 Camaro Z28
The Pioneer 77DH fits perfect in a 1991 Camaro RS. No modifications necessary. Easy install. $238 from MMXpress. Buy a wiring harness from Circuit city or somewhere $14.
Later,
Matt
Later,
Matt
skinny z
10-05-2015 06:23 PM
