Jim85, Rockford fosgate question for ya..
I purchased a rockford fosgate 800a2, I want my subs to sound good and hit well also, but I don't want to damage them.. Right now I have 2 infinity perfects, each wired to a channel (200x2@4ohms).. From what i've been told, if I bridge the amp and run both off the bridged channel, i'd be getting closer to 400 watts RMS.. The subs are rated at 350Rms but I've heard they can handle between 500-700 safely.. What would you suggest under this situation? Should I keep it at 1 per channel, or should I try to run it bridged, 2 ohm..
as u can tell, i am not jim85, but i have had some experience with rockford fosgate equipment. heres what i have found;
its ok to run those subs as they see a bridged load from the amp. as far as bridging the amp to 2 ohms, i would highly NOT recommend for a couple reasons. first, there are very few amps on the market that can handle a 2ohm bridged load successfully without going into "safe mode" and totaly shutting off. Rockford made a few (model 50m and 50.2 only) and i know soundstream made a few(the model #'s escape me right now). a 2 ohm bridged means that your amp is steady down the 1 ohm, which the RF800.2 is not.
as far as running either 2 or 1 channel, are those subs rated at 4 ohms or 2, are they dual voice coil(DVC) or single? because if they are 4 ohm speakers, you will not be able to run 2 ohms cuz only one channel from the amp will be used(and that would be pointless). which only leaves bridging the amp. if they are DVC, then you can configure the level of impedence to anywhere from 1 to 16 ohms. which means u can run 2 ohms out of each channel.
this is all speculation of course until you can let me know what specs are on those subs. if any of this seems confusing, my apologizes to you. let me know if you want me to explain this kinda stuff to you.
hope this helps,
daniel
86 camaro cpe(dont laugh)has 92z28 body kit with GTS covers, new red paint and a killer stereo. 2 amps, 8 speakers, disc changer, custom install with subs coming by the end of the summer. sawpped (or in the process of) 305lg4 for brand new 350. TES headers, flowmaster cat back, performer manifold, TCI converter, jet chip, kn with dual snorkel cleaner. and she still passed the sniffer!
"Cal Poly SLO is the shi#"
hope this helps,
daniel
The subs are 4 ohm, SVC... I don't understand why the 800a2 wouldn't run a 2 ohm bridged load? The 360a2 that I returned ran in a 2 ohm bridged load when I had it...
The 800 will be fine running a 2 ohm bridged load, just make sure that you have adequate ventilation because it's going to get real hot. The 800 will be a good amp for those subs. Subs can absorb a LOT of power if it's clean, undistorted power. My Zr 600 benched at 800 watts RMS into 4 ohms bridged, and I'm running a pair of Oz subs bridged into a 2 ohm load. The Oz subs are only rated at about 250 watts but are doing just fine.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
jim, i think u are wrong on this one. if you look into a manual of one of those punch amps, you will see that it is not ADVISED that you run it at 2 ohms bridged, that is like letting the amp see 1 ohm, which these new punch amps are not capable of seeing. your kicker is different from the punch series, im only saying that Rockford corp doesnt advise running those amps at 2 ohm bridged or 1 ohm stereo. only the rf 50.1 and 50,2 "competition" amps should be run at that impedence, i have the manual to prove it.
daniel
daniel
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I've generally found that quality amps can easily go at least the next step lower then what is printed in the manual. As long as you have proper ventallation, there shouldn't be a problem. I've run several Alpine V-12 amps bridged at 1.5 ohms without a hitch, even though the manual doesnt say it can.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
-Justin-
daniel
daniel
The IROC Homepage
