After making custom kick panels, how do you install it?
Old 03-03-2014 | 12:21 AM
FreeSpirit's Avatar
Car: 92 RS
Engine: 305 TBI
So I've been reading a lot about making custom fiberglass kick panels, and watching tons of Youtube videos. I feel pretty confident about it, and can't wait to do it when I have more time.
The only thing I'm wondering about is.. once everything is all done, and you painted or covered it.. How do you actually go about attaching it to the old kick panel? In all the custom fiberglass kick panel videos and projects I've seen, I don't see any screws showing, especially not in the painted ones. Would screws through the fiberglass and into the plastic even be strong enough to hold it? Or would you drill into the metal? If you do use screws, how do you go about hiding them?
I also have a completely unrelated question, just out of curiosity, in case I ever put a manual transmission in my car, or get a stick shift third gen. If you have the cardboard door panels, is it possible to add MDF/fiberglass speaker pods, or would you have to redo the whole door panel with MDF?
Old 03-10-2014 | 10:00 PM
visitor's Avatar
Car: genesis, equus, f250, camaro, other
Engine: 5.7
Transmission: t5
Re: After making custom kick panels, how do you install it?
Most people I know glass the pods to the kick.
Id not mount a pod to the door panel, maybe bolt it to the door...
Old 03-10-2014 | 10:50 PM
Teal92's Avatar
Take your original trim piece and make the pods with those so it will snap right in. I haven't had enough time to play with the door panels yet to give you any viable info on that.
Old 03-11-2014 | 11:31 PM
FreeSpirit's Avatar
Car: 92 RS
Engine: 305 TBI
Thanks. So the lower part where it fits into the step pad, and the upper part where it fits into the dash area, should be enough to hold it? I was thinking that would work. The screws in the kick panel don't really seem to do much anyway. My kick panels stay in place even without the screws, although a little loosely. I just wasn't sure if it would still hold in place with the weight of a speaker in there. But I guess the fiberglass is strong enough to hold the speaker.
Old 03-12-2014 | 12:00 AM
Teal92's Avatar
It'll be plenty
Frozer!!!
01-19-2024 04:55 PM
Jeremys87
07-14-2022 09:08 PM
Vintageracer
01-10-2020 05:33 PM
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
z28addict8490
08-07-2015 08:48 PM
Quick Reply: After making custom kick panels, how do you install it?
