Another sub box in wheel well
1 Post
Car: 1985 Camaro Sport coupe project
Engine: 2.8 mild cam
Transmission: T$ V6 5speed manual 4.04 first
Axle/Gears: 3.42 Limited Slip
Just thought I share my sub box
Sorry I dont have the measurements, but it worked out to be to be two 10" Alpine's 500RMS at 2Ohms each in the box. Sounds fantastic, and thumps hard.
Note I cut the rear interior panels to get a premium fit
![Name: 20130426_120818.jpg
Size: 73.0 KB](https://www.thirdgen.org/forums/attachments/car-audio/349230d1501338054-another-sub-box-wheel-20130426_120818.jpg)
And with the fold down hatch closed.. Cant even tell the sub box is there
![Name: 20130428_233356.jpg
Size: 104.2 KB](https://www.thirdgen.org/forums/attachments/car-audio/349231d1501338054-another-sub-box-wheel-20130428_233356.jpg)
A closer look showing where I cut the interior panels to fit the amps on each side.
![Name: 20130426_121314.jpg
Size: 86.2 KB](https://www.thirdgen.org/forums/attachments/car-audio/349232d1501338054-another-sub-box-wheel-20130426_121314.jpg)
![](http://i21.photobucket.com/albums/b259/Fordvette/20130426_121251.jpg)
![Name: 20130426_102757.jpg
Size: 81.5 KB](https://www.thirdgen.org/forums/attachments/car-audio/349233d1501338054-another-sub-box-wheel-20130426_102757.jpg)
Bottom of the box, I pointed the subs down, as directionally is not really a issue with closed box subs, so Im told. There is two inch feet on the box to keep the woofers from contacting the bottom, and there is a two inch air gap on each side
![Name: 20130426_102251.jpg
Size: 77.3 KB](https://www.thirdgen.org/forums/attachments/car-audio/349234d1501338054-another-sub-box-wheel-20130426_102251.jpg)
hope it gives ya some good ideas for future builds
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Re: Another sub box in wheel well
now thats clean!!really like how you did it......love the stealth look...ppl woudl never expect you got 2 10" subs
Car: 1987 Firebird Formula
Engine: 305 4bbl
How do those pioneer gm digital amps run, I just got mine but haven't gotten it hooked up yet.
1 Post
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
This is what I managed to stuff in the Camaro..
Pioneer AVH-x8500BHS Double Din 7inch touchscreen deck
Pioneer GM-D9601 2400w mono amp
Pioneer GM-D8604 1200w 4 channel amp
Pioneer TS-A6985R 100w RMS (500 maz) 6x9's
Pioneer TS-A1305c 60w RMS 150max 5.25 Kick panel speakers
Infinty Kapa 429.9 4x6 60RMS 180max dash speakers.
Alpine SWS - 10D2 500RMS 1500max Subs times 2
https://www.thirdgen.org/forums/memb...ort-coupe.html
Engine: 305 4bbl
Nice setup. I'm hopefully gonna get my box built in the next couple days. Do you have any pics of the kick panels installed I need more sound coming from the front of my car, right now its all in the back.
1 Post
these are the Speakers installed, wish I took more pictures of building them. Basically I just custom cut a piece of MDF to fit over the shape of the kick panel, and then laid out where I thought the speaker should fit. Then after I got the shape of the kick panel to where I liked it, I just found some old fabric and stapled it to the panel.
![Name: 20130514_1043421.jpg
Size: 190.6 KB](https://www.thirdgen.org/forums/attachments/car-audio/348916d1501337508-another-sub-box-wheel-20130514_1043421.jpg)
![Name: 20130514_1045161.jpg
Size: 127.7 KB](https://www.thirdgen.org/forums/attachments/car-audio/348917d1501337508-another-sub-box-wheel-20130514_1045161.jpg)
1 Post
![Name: 20130430_1651301-1.jpg
Size: 77.5 KB](https://www.thirdgen.org/forums/attachments/car-audio/348909d1501337491-another-sub-box-wheel-20130430_1651301-1.jpg)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
I will say I really like this idea and am borrowing part of it for my own box. Difference being Im going to use a 12" sub and it will be much flashier. Box will the the same shape, but the bottom is solid. Sub will mount in the top, upside down with the voice coil facing outwards. Amps will be mounted in the same locations as yours. I also plan on having 2 small plexiglass windows on either side of the sub with some blue LEDs inside. The windows will have the Z28 logo frosted into them.
My original plan was having the sub mounted the same as yours and a large plexi window on top to see inside, but a 12" sub wont fit at the bottom of the well with enough room for box material. And before anyone else comments, yes I'd rather redesign the box to fit a 12 than just go with a ten. I have a certain sub picked out and it's only available in 12 or 15 inch sizes.
Either way, thanks for the inspiration to something different rather than the typical sub box for these cars.
1 Post
![good idea](https://www.thirdgen.org/forums/images/smilies/goodidea.gif)
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
That will be another difference between the 2. I am going to try to have the top be all one peice right across the entire hatch.
Actually, that just gave me another brainstorm that will help with material costs... instead of the plexi windows being part of the boxtop and needing to be 3/4" thick, I can make the box top, then make a large plate with the appropriate cutouts for the amps and sub to fit through. Cut the windows into that and have much thinner plexi make the light up windows in the plate rather than the box.
1992rs/ss
16
01-28-2016 09:58 PM
backtothe80s
09-05-2015 12:39 AM
