how to get BIG Bass in a vert
I was just wondering if anyone has ever had custom sub enclosure in the trunk of a xonvertible camaro? Im used to heavy bass and wanna see if anyone has achieved that in a third gen vert, thanks guys
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Re: how to get BIG Bass in a vert
With the separation between the trunk and the passenger area, you're better off designing the system for low, deep bass. You're not really going to "hear" the bass so you'll need to design the system so you'll feel more bass.
An Image Dynamics IDMAX 12 in a larger sealed enclosure with about 600-1000 watts should do it. Jump on it now, too. They're on sale at insanely low prices. One should be sufficient, as I know there isn't a lot of trunk room in a convertible.
http://www.sonicelectronix.com/item_...***-zAod-Sz4mw
I'd shoot for the 1.3 cu/ft if you can. Even if you have to mount the sub with the magnet out, try to get the box as large as you can.
For an amp, you'll want a good brand. JBL, Infinity, Boston Acoustics, etc. No Pyle, Hifonics, Boss, or none of that lower end stuff.
Harman Audio has excellent deals on refurbished amps on their site right now. They still come with a full 1 yr parts/labor warranty, so don't be concerned that they're refurbished.
This one is a hell of a deal for 700 watts of clean, acoustic power.
http://www.harmanaudio.com/search_br...7001-Z&status=
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
What type of battery / alternator set up does this require? Can it be run from a standard 105 amp alt and single battery car or are other power components needed?
LT1Formula
10-08-2015 08:34 PM
3.8TransAM
10-01-2015 07:47 PM
