Speaker rms versus amp rms....
Car: 85 Camaro Z28
Engine: 5.7 TPI
I am adding a pair of Boston SE65 Speakers to my car and will be also installing a Rockford Fosgate R400-4D amp. The speakers are rated at 35W RMS, and the amp is rated for 75W RMS per channel.
Will it be ok to hook the speakers up to this amp without destroying them since the amp rms is double the speakers rating? Or how should I install these? Should I wire both speakers to a single channel?
I am still debating on the amp, but more than likely will be getting this one locally new in the box for $100.
Car: 85 Camaro Z28
Engine: 5.7 TPI
Re: Speaker rms versus amp rms....
But each channel is rated at 75w per channel, so wiring each speaker to their own individual channel, I would be overdriving them by 40 watts each...
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
You can over power them just turn down the gain so you don't blow the speaker what is the rms watts on amp and what are the rms on speaker not peak watss and is it a 4 channel amp
Engine: 305 to 350
Axle/Gears: 10 Bolt
You need to see the ohms of the speaker vs ohms on amp depending how you wire it the resistance will lower your rms too
Engine: 305 to 350
Axle/Gears: 10 Bolt
That's a lot of resistance 4 ohms o ohms is no resistance you would be fine with that amp
Car: 1987 Trans Am
Engine: LQ9/L92
4 ohms is standard for car auto equipment, no worries there.
yes, you will be completely fine hooking up those speakers to the amp. just because the amp can put out more power than the speakers can technically handle, you're not going to be playing test tones at full tilt at all possible times.
better to have too much power on tap than not enough.
PLEASE tell me you are kidding.
Keep the gain **** down about 1/2 way from full power and you will be ok bro. The amp does 75 watts RMS and with the 35 watts rms rating of the speakers you need to be careful.
MAX power ratings are a joke. Some speakers can go WELL over the 'max' power, and other's cannot take even close. RMS is the numbers to look at.
Unlike subwoofers, speakers RMS ratings are usually realistic.
J
Car: 87 camaro iroc
Engine: 5.7L
J
J
Also agree rms is the thing too look at. once bought a woofer with 1200 peak powered it with 1000w amp, this being back in the day before I knew anything, and it lasted for a little while. Turns out its rms was 300 and the amp was 500 rms, live and learn lol.
Anyway not sure if its too late but like i said you prolly don't even need an amp for that rms, look at the specs on your head unit.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Play with the gains on the amp until you're satisfied. More headroom is better.
raymondandretti
09-27-2015 06:43 PM
