My 6 inch speakers in the door
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
This might be useful, it would have been for me putting them in. I put some 6 inch speakers in the door of my 90 camaro. It doesnt have window motors which probably made it easier. There is a perfect cutout in the metal of the door frame that the speakers fit into and they sound great. Heres a pic
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
Re: My 6 inch speakers in the door
How do you roll your window down?
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Yeaaah, I'm thinking this was one of those ill-thought out ideas.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Just saw an ad for extensions for the manual window cranks.
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
Yea I realized that AFTER I put the speakers in hahah it was a complete fail moment. But the crank barely scrapes on the grill now and is totally usable. Taking the crank into consideration before hand it would be easy to correct for it with extensions or a different grill.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
got a pic of the metal behind the panel to see what you cut out?
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
I didn't have to cut at all! only drill holes, there is already a pre existing hole that it fit right into. it was maybe a 4 hour job
Car: 89 IROC-VERT
Engine: TPI 305
Transmission: 700R4 Auto
Axle/Gears: 2.77
Wow! Is that the speaker wire coming from the hood latch? Dude are you serious! Hahahahaha
That's nothing, the PO's of my Camaro had a wire running under the dash pad to a CB, they had a LOUD SPEAKER under the hood! I yanked the wire recently, somehow they had it ran between the fender, through the door jam.
Anyhow, good job on the door speakers, just, hide that wire a little better.
Hotrodboba400
12-10-2019 07:07 PM
84 TA NV
09-06-2015 08:02 PM
raymondandretti
Exterior Parts for Sale
09-06-2015 12:51 AM
