pics of my Sony Xplode system
Old 12-05-2011 | 03:15 PM
larochelle's Avatar
Car: '84 Z-28
Engine: 355
Transmission: 4L60
just installed Phase 1 of my stereo system. bought the headunit, amp, 4X6's, 6X9's, and 12" subs's on ebay and CL. Then made my own 3/4" MDF box. sounds pretty good but the 6x9's were in pretty bad shape ( bad ebay seller ). Gonna cover the box someday when I install new carpet and fix-up the rear plastics. For now gonna concentrate on other fix-up's. Hopefully I will be updateing soon !
Old 12-05-2011 | 03:30 PM
larochelle's Avatar
Car: '84 Z-28
Engine: 355
Transmission: 4L60
Re: pics of my Sony Xplode system
The head unit was also missing the trim piece for the mounting bracket but i am planning on flush mounting it in phase 2.
Old 12-06-2011 | 10:46 PM
darion45405's Avatar
i would advise you to use rubber grommets to somewhat isolate the amp from the vibrations of the subs. i have destroyed a couple of amps mounting them directly to the box.
Old 12-06-2011 | 10:51 PM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Sweet man. Looking to do this myself. I'll let you make the mistakes though so feel free to update your proggress! ; )
Old 12-07-2011 | 06:06 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Just a heads up, alot of people look down on Sony xplodes. So if someone says anything I'd just ignore them. I'm running a fully Sony xplodes set up in my car besides my amp and cap and I can be heard about a block away and can rattle the house windows
Old 12-07-2011 | 07:04 AM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
The red matches your car
Old 12-07-2011 | 07:18 AM
larochelle's Avatar
Car: '84 Z-28
Engine: 355
Transmission: 4L60
Yep, thats why I went with an all Sony Xplode system, and it matches my gauge lights.
Old 12-07-2011 | 07:23 AM
Keep the pics comming, lets see how it looks when you are done
Old 12-07-2011 | 11:53 AM
Andrew James's Avatar
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
Mebbe cause you can buy the full system for eighty bucks at Wal Mart so every highschool kid has them?
Old 12-07-2011 | 02:01 PM
larochelle's Avatar
Car: '84 Z-28
Engine: 355
Transmission: 4L60
I personally have seen alot of amps mounted directly on speaker boxes and have never heard of subwoofer amps going bad from vibrations.
That is why they are a great choice, I could easily spend more on the stereo than I did on the entire car. There is no point putting high end speakers in a 25 year old car that is built for speed. I believe I spent around $180 for the entire system shown.
Old 12-07-2011 | 08:16 PM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
That's a pretty decent head unit, I used to have the cassette equivalent. I loved the built in 7 band graphic EQ and 10 disc cd changer controls...only reason i switched is because i wanted USB capability.
Old 12-07-2011 | 09:33 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
can you by any chance get the dimensions of that box? looks great!
Old 12-07-2011 | 10:07 PM
Awesome-X's Avatar
Car: 87 Camaro
Did your front speakers come with the plastic trim that lets you use them on your original speaker frame?
Old 12-08-2011 | 09:29 AM
larochelle's Avatar
Car: '84 Z-28
Engine: 355
Transmission: 4L60
Yep, the speakers bolted right in with no modifications. You can see the trim ring in the first pic they are made to fit many applications.
Old 12-08-2011 | 10:45 AM
Awesome-X's Avatar
Car: 87 Camaro
Did you use the 4x6s or the 6x9s in the front? I'm guessing 4x6 but I wanna make sure.
Old 12-08-2011 | 11:00 AM
larochelle's Avatar
Car: '84 Z-28
Engine: 355
Transmission: 4L60
4X6's Model # xs-w4621 $30 Brand new on Ebay
Old 12-11-2011 | 12:12 AM
i have done it twice myself. the heat the amp generates weakens the circuit board connectors for the power wire. one actually grounded out and blew both the fuse on the amp and the one under the hood.
Old 12-18-2011 | 08:57 PM
larochelle's Avatar
Car: '84 Z-28
Engine: 355
Transmission: 4L60
You can see I had to round the rear corners to make it fit snug... I have now bolted it down and it fits completly flush with the rear deck. I am still thinking about how I am gonna finish /cover the box.
Old 12-19-2011 | 04:53 PM
patricklav's Avatar
Car: 92 Camaro Z
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
Any fitment issues with the Sony Explods? plug right in no problem?
Old 12-19-2011 | 06:35 PM
Awesome-X's Avatar
Car: 87 Camaro
I don't see why they wouldn't, they're speakers like every other speaker.
Old 12-19-2011 | 06:44 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
As with any set up I would want to read it right side up when I opened the hatch. When you open the hatch and find it upside down it just looks a little strange. What do I know, maybe there supposed to be that way ? Other than that I can see that you have put allot of work into it. Good job.
Old 12-19-2011 | 07:25 PM
patricklav's Avatar
Car: 92 Camaro Z
Not every manufacturer's 4x6 fits in the front.
Old 01-09-2012 | 02:44 PM
K. E. Christy's Avatar
Car: 1991 Z28
Engine: 5.0L TPI
Transmission: 5 Speed
larochello,
This is my finished unit. Had custom piece of carpet embroiderer. Just need some sound deading material to the underside a carpet to add weight and lay flat
Old 01-11-2012 | 09:26 PM
larochelle's Avatar
Car: '84 Z-28
Engine: 355
Transmission: 4L60
I actually put the amp in like that because the power wire would only reach like that, it was about 2 feet short. I wasn't originally gonna do it that way but have grown to like it.
Old 01-11-2012 | 09:29 PM
larochelle's Avatar
Car: '84 Z-28
Engine: 355
Transmission: 4L60
Originally Posted by K. E. Christy
larochello,
Ya, I like yours. I am planning on new carpet soon and will finish it and make it a single piece that covers the rear and subs... my plastics need alot of work too.
Old 01-12-2012 | 06:06 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Is thebox partitioned or is it shared space? I'm also curious on the internal volume, I like my baffle board for simplicity but you can't beat a sealed enclosure
Old 01-12-2012 | 09:11 AM
Car: 1991 Z28
Engine: 5.0L TPI
Blufdy
I don't know who are asking the question to but mine is neither ported nor partitioned, just sealed. The carpet really makes the look nice, removing the seam.
Old 01-12-2012 | 06:12 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Oh sorry that was to the OP. By partitioned I was referring to if the subs share the air space or if they are seperated by another piece of mdf
92projectcamaro
01-18-2016 08:00 AM
83 Crossfire TA
01-03-2016 01:26 PM
69 Six Pack
10-05-2015 07:51 PM
Slush92RS
09-02-2015 08:56 PM
Quick Reply: pics of my Sony Xplode system
