My Audio System
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
My Audio System
How do you think this sound: JBL 5x7 woofer/tweeter component set and JBL 6.5 3 way center for the dash (Both GTO Series). A 6.5 in Kicker sub in the door and a Kicker 5 & 1/4 woofer/tweeter component set (KS Series) in the kick panels. JBL GTO 6x9 3 ways in the sail panels. Kicker 10" subs and and 6 & 1/2 in KS series woofer/tweeter component sets in the rear well area. Gonna run 3 JBL GTO 600 watt 4 channel amps and a JBL GTO 700 watt monoblock amp
Car: 1987 Trans Am
Engine: LQ9/L92
Re: My Audio System
that is waaaaaaay too many speakers to be installing and will make tuning correctly impossibly. keep it simple; components in the kicks, sub in the hatch, and something in the b pillars for rear fill.
what is your end goal and what is your budget?
Car: 1987 Trans Am
Engine: LQ9/L92
Re: My Audio System
less is more if you're trying to sound good or compete; get a quality set of components in the kick panel, a good sub, a good deck with some eq and crossover adjustments, and amp everything. too many different speakers in different locations destroys the sound stage and will not sound good.
quality parts tuned right will sound 100x better than a large quantity of cheap parts
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: My Audio System
alright thanks. So how bout 4x6 plate speaker in dash, kick panel components, 6x9s and 2 10s in the back?
Re: My Audio System
When it comes to sound quality systems LESS is more.
In my systems I run a pair of front speakers (usually a component set), and a sub or two, along with either a 4 channel or two amps, one being dedicated to the front speakers and one being dedicated to the sub.
I just installed a very simple system, in a friend's '66 Mustang,that consists of a pioneer 5.25" component set, two Phoenix Gold Xenon 10s, and two Phoenix Gold amps, one being dedicated to each set of speakers.
It sounded PHENOMENAL! I spent a LOT of time shaping the kicks to try and get a sort of horn/guided effect and it seemed to have paid off. The subs are in simple sealed enclosures, and a single CD deck is the source. Simple system with good construction techniques, and thought out placement, and integration is key.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: My Audio System
alright thanks alot. Glad i said somethin, I was gonna run a ton of speakers but now i aint. Just my kick panels and sail panels. Any advice on a center channel speaker? where to mount? Or just dont do it at all?
Re: My Audio System
I would also personally nix the rear speakers, or at the very least NOT install them in the sail panels/B-pillars, since they will end up closer to your ears than the front speakers, which means you will hear them first and pull the stage rearward.
If I really needed to install rear speakers I would move them as far back as I could. This increases the distance to your ears, and the time it takes for the sound to reach your ears. This will also help create a larger sounding venue, giving a greater front stage.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: My Audio System
so make some custom speaker boxes for my 6x9s about middle of the hatch? or need to move them further back?
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: My Audio System
I agree with six_shooter. Less is more.
How about a 6.5" comp set with the tweeter in the a-pillar, mids in the kick or door and subs in the back.
Fairly classic setup.
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: My Audio System
alright ill try it thanks everybody for the advice
Car: 1987 Trans Am
Engine: LQ9/L92
Re: My Audio System
there were a couple guys a few years back that made kick panel enclosures for our cars, if there are any sets in the classified ads, grab em (thats what i did). they're much beefier than the qlogic ones, but those can be good with a little fiberglass on the backs. a throw components in there, forget the dash. a good sub and a 4 channel amp is a great start. leave the rears to run off deck power. get a good deck with 2-3 sets of preouts and whatever features you want (mp3 is great for convenience, eq/time alignment/crossover adjustments are great for tuning). i loved my pioneer prs880, regret selling it
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: My Audio System
well i am gonna make my own door panels and put the 4th gen style speakers with 6 &1/2 and tweeter components and do that along with my sail panels and 2 10s
Pac J
05-17-2020 10:44 AM
[Sold] Flowmaster exhaust system
Night rider327
10-09-2015 09:25 AM
Night rider327
09-25-2015 04:47 AM
