can subs bust t-tops?
i am in the market for purchusing some subs for my car i wan't to put 2 ten's in the trunk but if i had the bass to loud and had my t-tops straped in my trunk could it posibly shatter my t-tops? or does anyone know if this is possible lol just don't want to end up in a bad situation
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: can subs bust t-tops?
no they wont...it would be pretty much impossible to bust a t-top like that, you would have to find a way to seal your car at every air gap before it could bust a t-top. and even that is unlikely
edit:
i read your post wrong...no its not going to bust a top in the trunk...its hard to get them to fit in the back with subs though youd be better off putting them in your backseat or leaving them at home.
edit:
Car: 89 Formula
Engine: LB9
Transmission: WC T-5
When I was younger and dumber, I had 2 12" jl w7's being fed 2,000 rms each. It would pop the windows out of the weatherstripping, and it will even blow out the rear hatch glass, but it wont hurt your t-tops.
Thirdgen89GTA
11-26-2015 11:04 PM
