Is it good Car Audio Subwoofer Box?
Hi,all guys,has anyone of u have experience with Car Audio Subwoofer Box?How about its sound quailty and performance?Is it worth?
I want to get one for my car,do u have any other good recommendations?
Thanks in advance!
Thanks in advance!
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Is it good Car Audio Subwoofer Box?
hate to say, but stay far away from something like that. cheap materials, poor quality speakers, not worth your time. save a few more dollars and get stuff that will fit correctly in the vehicle and sound good
that is a perfect box for having some noise while tailgating, about it
Car: 89 Camaro RS
Engine: 350 TBI
Axle/Gears: 10 bolt/ 3.23 Gear.
I have to agree...
Do take the time to get proper fitting boxes, not only will it look better, the quality is MUCH better in the end.
http://www.sonicelectronix.com/item_...-Trans-Am.html
This is similar to the one I have, but I dont have the FULL depth (wish I did) but it fits perfectly and the carpet almost matches a grey interior. I do have 2 12" subs at 1000watts, and its not to much that it sounds bad. I did stick a bit of rubber behind the license plate though, cuts down on rattle at high volume. I think my box was $100, I'll go get a picture.
Car: 89 Camaro RS
Engine: 350 TBI
1, 2, 3.
The extra cash and time REALLY pays off in the long run. Dont go with anything less but quality on your audio as you would with the rest of your car parts.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Just remember that the box needs to fit the air requirements of the sub(s) you buy.
The sub, power and box all need to match, otherwise you'll have less than optimal sound.
Car: 89 Camaro RS
Engine: 350 TBI
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Try. WWW.subthump.com they make custom sub boxes 3/4 thick mdf wood.
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
https://www.thirdgen.org/forums/car-...0-sub-box.html
i have everything installed, ill try to post a picture tonight!
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
There's a pic of mine floating around here somewhere... The box is 5/8 MDF prefab and cost me about $200. Only problem with it is that the carpet was separating from the wood down in one of the lower corners of the box where it sits in the well when it came out of the package...
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Might want to clean that wiring up A LOT... That's just begging for a break in.
Car: 1987 Trans Am
Engine: LQ9/L92
1. bolt the amp down to something safe (screws into the sheet metal here are bad news because of the gas tank)
2. cut channels into it to route wires underneath amp.
should make things look cleaner while also making things safer and harded to steal
Engine: L31 350
you could always put a board underneath the carpet and use that for a few purposes:
Engine: 2.7L V6
Axle/Gears: 4.41
The way I had mine was mounted to a board screwed into the front of the sub box with brackets hidden under the amp. The wires were tucked under the board and down under the sub box where they ran into the back of each side. Also, that enclosure is quite small for those subs (1.0 CF, IIRC from my 1200W Sony)... They may sound better if you take the subs out and buy some pillow/craft filler (probably one large bag per side) and put that in each side of the box under each sub.
Terrell351
06-13-2021 02:13 PM
Linson
08-21-2015 03:12 PM
1989, auto, box, camaro, enclosures, fit, g8, high, maverick, performance, pontiac, speaker, subwoofer, subwoofers, thirdgen
