Amp Power Wire Hookup Help
Old 01-21-2011 | 04:06 PM
Andrew1320's Avatar
Car: 1990 Pontiac Firebird
Engine: V8,350,5.7 L.
Transmission: Automatic - 700r4
So I'm really getting mad but I need to hook up the amp power wire to my batter on my 1990 Pontiac Firebird and can not get the bolt to tighten down. Someone please help!
Old 01-21-2011 | 04:17 PM
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
Re: Amp Power Wire Hookup Help
It's a real pain getting a power wire behind the side terminal. You only have so much room. What I did was bought a cheap terminal for the top post and ran the power wire off of it. I don't know if your battery has top and side terminals though....
Old 01-21-2011 | 04:27 PM
Andrew1320's Avatar
No it just has side terminals...
Old 01-21-2011 | 05:19 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
They make a bolt to do this with - available at any auto parts store in the battery section - it replaces the bolt in your battery cable, but has another threaded section at the top with another nut to attach an eyelet cable end (the amp wire needs an eyelet crimped on it.
http://www.autozone.com/autozone/acc...questid=142637
And the eyelet to crimp on the amp wire (which it should have had one):
http://www.autozone.com/autozone/acc...questid=143180
Old 01-21-2011 | 06:10 PM
87350IROC's Avatar
Car: 87' IROC
Here is what I used for a little while.
http://www.bestbuy.com/site/Fierce+A...&skuId=9855376
Worked fine.
Old 01-21-2011 | 06:43 PM
Andrew1320's Avatar
Thanks!
Old 01-21-2011 | 11:21 PM
F_BODYKING NC's Avatar
Car: 1988 IROC-Z ,1991 RS
Engine: 350 TPi , 305 TBI
Transmission: 700r4 ,t56 sixspeed
Axle/Gears: ?
hay man i been there if you havent got it yet auto zone has a batery terminal you take out tha old one and it has 2 sides so can put tha bat lead on then your amp wire on tha back side tha you are good to go
BRoss99
12-07-2020 07:50 PM
mustangman65_79
Car Audio
09-08-2015 09:20 PM
Bert87
08-23-2015 04:50 PM
ZsTransAm
08-11-2015 08:30 PM
