speakers crackling
Car: 88' sport coupe camaro
Engine: 5.0l v8
speakers crackling
my speakers are cracking so bad people keep telling me if i buy a new headunit they wont crack anymore but i thought i would see what everyone had to say first
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Playing Ice Cracked His Speakers
Might be too much bass.
What is the power capabilities of the speakers?
What is the power capabilities of the amp?
Happy Racing!
I’ve NEVER Hit The Wall! - The Safer Barrier Prevented It
Happy Racing!
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Re: Playing Ice Cracked His Speakers
Mine used to crackle and I couldnt turn them up to loud. At the time though only my rear driver side speaker worked. Me and my friend ran new wires to all the speakers (it was a rats nest and took about 3-4 hours!) and the speaker that was crackling we just replaced it with one in his garage and now I have an awesome sound system!
So it might just be that you need to replace them or that you need to run new wires. Start with the cheap repairs and work your way up until you fix the problem.
1 Post
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
Re: speakers crackling
Do you have an aftermarket deck ? If so turn the bass down and the hpf filter on if you still here it , its probably blown. And when you replace it make sure it doesnt happen again. set your bass and treble up properly if you need more bass get a sub.
If your music is playing all the time with no break then its probably not the wires
Also is this your front 4x6 speakers or your side 6x9? or all 4? might help in trouble shooting the problem.
Engine: 5.0l v8
my front right speaker is blown really abd and crackles to bad same with my right rear speaker my other two are fine
Car: '85 Sport Coupe/Z28
Engine: N/A 350
Transmission: TH350
Axle/Gears: Factory 10-bolt w/3.08
It can happen if you happen to have solid core spark plug wires. Or a high output ignition.
http://www.magnecor.com/magnecor1/truth.htm
Check out the second two headings.
1 Post
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
buicks of the same year have a bad capacitor problem that causes crackling.im not sure about camaros.
Car: 88 Camaro IROCZ Convertible
Engine: 305 tbi
Transmission: auto
I jus figuired out my issue , the wire from the speaker cone to the terminals was touching the speaker frame and shorting or grounding out (not sure of the term) but i seen it sparking so i put a peice of eletric tape on the frame under the wire and now im good! But putting in the passenger speaker is not easy for me... Not sure if its the same for everyone
