HU Mount
Car: 87 Iroc z
Transmission: AT
HU Mount
Got my HU mount installed.... was kinda a pain but it turned out looking much much better then the aftermarket kits that stick out about 1/2"
Car: 1986 z28 & 1992 z28
Transmission: 700-R4
Re: HU Mount
Did you have to "modify" the heater vents to get the thing installed? I had to destroy mine, and I really wish I hadn't...
Car: 87 Iroc z
Transmission: AT
Re: HU Mount
I noticed that VERY little air was actually coming out the console vents so i did cut the vents out in the back. Then i just put a peice of duct tape over the hole to keep the hot air from coming out onto the back of the radio. IMHO this was a poor design by GM. All that was keeping the air from coming out from behind the radio area was a sponge glued to the vent ducts where they came together. Now the floor vents work better without all that air "lost" behind the radio. Plus it looks much cooler
Car: 1985 Camaro Iroc-Z
Engine: LB9
Re: HU Mount
Thanks for buying that exact setup from HUmount, i put money in the paypal yesterday to buy a "camaro" "iroc-z" one but have only seen the TPI irocz one in this thread.
On getting power to the led, did you just grab a wire from the harness with 12v?
And what color is it when its not lit up? a off whiteish?
Car: 87 Iroc z
Transmission: AT
Re: HU Mount
Yes, make sure its the "power" lead not the ilumination lead like the instructions say... or it will only come on when your lights are on. Power lead makes it will burn when you turn your car on day or night.
Mine is Red so when the car is off its a deep dark red almost black. If i had to do again i might think about blue since the the radio is blue... but the red matches the Z28 emblem on the dash so....
Engine: LB9
Re: HU Mount
thanks alot 87, May seem silly but i was a bit worried you would see a white plastic with it off. that one pretty much sealed it for me
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: HU Mount
Great pics of the mount. I did not know about them. I like it and will get one when I am ready. It is a small but neat custom touch. It would be a perfect touch in my Bird after I get it running. Just something else on the wish list. At least this is relatively cheap.
Engine: LB9
Re: HU Mount
Yeah its definitely pretty, my interior is all stock (but extremely clean and in great shape, which makes the faceplate look even better)
The directions say to wire it up to come on with the lights, but with how strong the led is and the way its built i suppose, it glows perfectly fine in direct sunlight, so i wired it up to come on with the radio like camaro said
1 Post
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: HU Mount
This is what mine looked like when it was in the car too bad i didnt get a pic of it with it on. I also wired it up to the interior lights for the console.
1 Post
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
Re: HU Mount
hell yea i got the polished z28, red lit, Chevrolet underlined. the heater pieces i had to cut to fit, and it's hot on the shifter but i absolutely love it. worth the $70 something dollars. i woulda paid double.
1 Post
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Re: HU Mount
Definately going for blue CAMARO RS, but dont know if Multi-Port Fuel Injection will fit under it.
Thanks for the pics, keep posting em.
Anyone got a pic of the blue one??
1 Post
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: HU Mount
i like my 1.5 din pioneer.when it dies i'll try to find another 1.5 din radio of mod it for a double din radio.
Car: 1988 IROC-Z
Axle/Gears: 3.08 POSI Rear
Re: HU Mount
I recently installed a humount with blue illumination and it turned out great. I also had to chop out the air ducts behind the factory radio. The problem is now I cannot put the factory trim panel back on. Any suggestions? Thanks. I'll post pictures when I get the trim back on.
1 Post
Car: 89 IROC
Re: HU Mount
i had to chop the vents as well but i used h-vac ducting metal tape over the hole and made it so air could kinda flow still. dont really care if it does work but I had the tape so why not try. What problems did you have? does it bulge out? if so i just trimmed the back of the cover to fit properly
Car: 1988 IROC-Z
Re: HU Mount
It doesn't appear to stick out but it does because the trim plate will not go back on. I could trim it but I just assumed that since this is a factory mount replacement, that wouldn't be necessary. What tool did you use to trim? Dremmel? I'd prefer not to but if I have to, I will. Thanks
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: HU Mount
1 Post
Car: 89 IROC
Re: HU Mount
Pretty much what the project said accept I used a rasp file and it came out perfect
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
