re audio 12xxx subwoofer
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: re audio 12xxx subwoofer
RE makes some nice subs. I would have went with a XXX model, but got a deal on my CVRs.
Easy way would be take the specs off their website and make a cardboard mockup of the sub. That will give you a pretty clear idea how you will need to place it to get it to fit.
http://reaudio.com/specs.html#sp_xxx
A 12" might be doable, but a 15" and 18" with there 13.5" to 14.75" depth I wouldn't think would be easy without some serious cutting to get it in the hatch.
My Kickers are around 8" to 9" mounting depth if I remember right and they just barely fit with the cone size since they have to sit so high.
Car: 87 trans am, 82 trans am
Axle/Gears: stock
will any1 know the dimension for the 12xxx re audio, or do you know who can i ask?
Engine: 383 SBC
Check out the link I posted above. It has the measurements.
Axle/Gears: stock
Engine: 383 SBC
From the page:
Mounting Depth - 12.75"
Mounting Hole Diameter - 11.5"
Overall Diameter - 13"
Motor Width - 10.5"
Motor Depth - 5"
Basket Depth - 7.75"
Not sure how much more measurements can be posted. Most places only list the mounting depth.
So you're looking at 13" ring showing, 11.5" on backside of ring to a 12.75" depth. It'll taper in some from 11.5" down to a 10.5". That'll give you a pretty good idea on the shape.
Motor Width - 10.5"
Motor Depth - 5"
84 TA NV
09-06-2015 08:02 PM
