AM radio fix?
AM radio fix?
My AM radio has so much static when I'm driving that its almost not worth it. I replaced my plugs, plug wires and distributer cap with the best ones I could find but it hasn't helped much. Is there anything else I can do? Thanks!
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: AM radio fix?
Does it still do it when using a cd or tape? Only asking because I had a similiar problem once and I found the antenna plug was loose.
Car: 1991 Z28 Vert
Re: AM radio fix?
I used to see bad AM reception in cars that were grounded badly. Ground all of your audio to as close to the frame on clean bare metal. Sometimes I would even ground the shielding on the antenna.
